Results 31 to 60 of 79
Thread: MHZ FOUNTAIN and CASTLE 1717 1580kV
  1. #31
    FR
    2,094
    Here is the MHZ Fountain
  2. #32
    US
    5,557
    Wonder if an x442 will be a good prop choice for my 40" Vee with the 1717 on 6s..........???
    At least a starting point....................
  3. #33
    Oct 2008
    9,488
    I think bigger?
    I have the stock S225 on my Outlaw that I will keep on it when I try my 1717 on 5s and 6s
  4. #34
    US
    5,557
    Maybe so................i was wanting to start on the small side..........check temps etc.............and work up. It may well end up being a 445, 447 or s225............thanks.
  5. #35
    Oct 2008
    9,488
    I hope to be able to go upto a S230 and possibly a S235
  6. #36
    FR
    2,094
    DISAR build a MHZ Racemaster, his hull is 1 meter long like the Fountain. A Castle 1717 on 6S will give too much RPM, I think 5S will be ok, around 30000RPM, 5S 2P (parallel) should be a nice setup
  7. #37
    FR
    2,094
    What do you think about this hardware, lenght is 9cm ( 3,6"), is it enough for a 39" hull?
    This hardware is expensive, If you have links to cheaper hardware that' s great
  8. #38
    Aug 2007
    AT
    1,072
    The prop distance behind the hull is one big question. normally is 10%, but when I asked MHZ for the racemaster they said 55mm which is quite small I believe. I have it at 85mm and I use the eco trimax but I think that the speedmaster stinger is far better. I recommend the speedmaster stinger, very good quality, 83mm length and cheaper. 3/16 flex, teflon and 9/32" tube. the teflon just fits in the stinger very nicely.
    If you want longer distance you can install a distance piece on the transom or elongate the stinger, but need to find out how ...
    Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
    http://www.rcfastboats.com/
  9. #39
    US
    5,557
    I guess the 442 was too small, took my first run with my 40" fountain with the 1717 on 6s. Ran very well.............not a huge speed difference from the Feigao 580L but definately faster.............the thing is though, the 580L would come in at 125*, and the ESC fairly warm too. This motor came in after a 3 minute run at 78*..........yep...........78*. ESC was 83* and caps 89*, its a Seaking 180. This big boy wasnt even loaded up and i imagine that loading it would wake it up. I think the s230 mentioned by Brushless55 would be a good fit...........that or an Octura x447. I'll play with it.................
  10. #40
    6,453
    That motor will spin a MUCH bigger prop!
    Good luck with the Seaking on 6s though.
  11. #41
    Oct 2008
    9,488
    Bam!
    this is very awesome, another great run on the 1717!
    let us know how the S230 or the X447 run. I will buy a prop for my OSE Brothers Outlaw after you run yours
    do you have a cooling jacket on your 1717?
  12. #42
    US
    5,557
    Bam!
  13. #43
    Oct 2008
    9,488
    what motor mount do you have?
    I am having Peter make a mount for me, but I'm not sure that jacket will fit?
    and what do you guess your speed to be on the run?
  14. #44
    6,453
    Steve has jackets in stock now!
  15. #45
    on
    636
    Outta stock by morning I bet!
  16. #46
    FR
    2,094
    Quote Originally Posted by DISAR View Post
    Are you talking about this 3/16" Speedmaster Stinger Strut? http://www.offshoreelectrics.com/pro...os-stinger-str
    What 3/16" prop shaft and what 3/16" flex shaft work fine with the Speedmaster Stinger?
  17. #47
    Aug 2007
    AT
    1,072
    Alfa yes, this stinger, I believe that you have all the items needed for the shafting.
  18. #48
    FR
    2,094
    Thank you for your help DISAR, parts are on the way;
    The Speedmaster strut for 3/16'' look fine, What about the lenght 82,5mm?
  19. #49
    Feb 2010
    1,025
    Not sure if you seen my post on RR this is my current setup with uncooled 1717/1580
    40" AM Sprint Cat
    Etti HV 200 amp water-cooled ESC
    6S1P 30C 4500 Lipo
    X450/3 Prop detounged / 53MPH GPS no heat on anything
    X452 Prop detounged / 57MPH GPS no heat on anything
    I'm likin these motors!
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
  20. #50
    Dec 2008
    Ov
    918
    Alfa :
    The Speedmaster Stinger is even better than the others.
    Why ?
    You can adjust not only the angle, but also the HIGHT of the shaft !
    Lenght : 10% is not a "rule".
    Works well on stepped mono's with a SAW-setup.
    For a normal setup/hull you don't necesseraly need 10%
  21. #51
    FR
    2,094
    The Castle 1717 with his water jacket is a monster, great !!
  22. #52
    FR
    2,094
    Parts of hardware are on order The flexshaft and the coupler come from Dave Marles, out of stock at OSE
  23. #53
    US
    5,557
    Have this hull on the way for my Castle 1717. The old hull wasnt performing to my liking. Gonna run it on 6s............its 39.5".
    Question is, which prop? I'm thinking in the x445, x447, x642, x645 range. Any suggestions are very welcome and appreciated!
  24. #54
    Oct 2008
    9,488
    Looks like my Thundertiger OBL
  25. #55
    2,686
    I think the x452. Those props are kinda small for a hull that size. I ran the m545 on a castle 2200 with no heat issues. The 1717 will push those props without breaking a sweat!
  26. #56
    US
    5,557
    OK...........seems kinda big, but thats why i asked. Thanks!
  27. #57
    FR
    2,094
    I need help guys, how many rudders for the MHZ Fountain? I think that I will install two rudders for stability, what do you think?
  28. #58
    Aug 2007
    AT
    1,072
    If it is the thunder tiger OBL, it can do well with small props as well. I ve seen one with a prather 220 and a 642. Depends on the position of the strut, if it is low small props can work, if it is high you need bigger props.
    Depends also on your esc, 225,230,445,645 are definately safe, then if temps-amps are ok bigger ones can be used
  29. #59
    US
    5,557
    Thanks DISAR................ got my hull in, got all the parts too.................just gotta pace myself as i tend to wanna rush things a bit and i want this to be as close to perfect as i can get it.
    Not trying to hijack your thread alpha..........we both have 39" mono's with 1717 power and i thought id share mine as well.
  30. #60
    Oct 2008
    9,488
    I think yours make for 4 of us building a 39-40" mono with CC1717 power
    https://forums.offshoreelectrics.com/...ad.php?t=19194
