Results 1 to 12 of 12
Thread: brushless mini cat?????????????help!!!!!!!!!!!!!!!!!!
    Jun 2010
    fl
    7
    Question brushless mini cat?????????????help!!!!!!!!!!!!!!!!!!
    i have put a 370s 4400kv brush-less motor and a water cooled 20 amp esc with a 3s lipo in a mini c hull along with a spectrum receiver and new servo. The running gear is all the same except for the prop shaft witch is now threaded to take different props. I have tried three different props all about the same as the stock mini rio prop with different pitches i have even filed one down to half the original diameter and tried it all with the same result. the boat just flips no mater what. even when i try to be gentle with the throttle it just flips before it even gets on plane. with the moded prop i could just get it on plane but it still wanted to lean hard right and the cavitation was horrible. Anny prop or drive advice would be greatly appreciated.
    Nov 2009
    Ca
    2,686
    Drop down to a 2s pack. Thats almost 50,000 rpm on 3s!!! Too much.
    Apr 2010
    3,480
    Volts X Kv = max RPM
    Max RPM should be 25-35k
    You can use a piece of #128 K&S brass as a shim and use the Venom 32mm props. But with 4400kv, wow, 35000 RPM that's about 55mph or more in that little hull!
    I did a similar build on 2s with 2900kv motors and 32mm props. No room for GPS, but it was wicked fast!
    Jun 2010
    fl
    7
    thanks for the answers, but my problem is it wont even get on plane without flipping.i have tried just slowly working it up but it still flips. The one time i did just hit it it flew out of the water about 4 feet spinning around, busted both universals, and striped the servo gears. I don't have any 2s laying around so i will just bring my throttle rate way down on the tx for now. Also if i put a regular mini strut and rudder on like diegoboy did on his, will this help at all with the rolling problem?
    Apr 2010
    3,480
    Where is the COG? It should be about 27-30%
    But , if the power delivery isn't smooth, it's going to over power that little hull and flip. Should be running at about half that RPM. JMO
    Jun 2010
    fl
    7
    my cog is 5 inches forward from the transom on the 14 in hull and the lipo is on the far left side of the hull to compensate.
    Apr 2010
    3,480
    Quote Originally Posted by reelredneck View Post
    Might try moving it back to 4".
    You might try taking a vid of the behavior, it will tell us more than a description.
    Jun 2010
    fl
    7
    OK thanks I'll try moving it back a bit and I'm headed to the lake right now. I'll try to get a good video.
    Jun 2010
    fl
    7
    Thank you, fightercat you have been a great help. I put a new octura red 30 mm prop on it and took my throttle limit down to 60% with 25% expo. I took the cog back as far as i could to 4.5 in from the transom and it runs much better.
    At 60% throttle(max for now ) it still tilts right and wanders to the right but it is still bearable i just have to do a little compensating. The only problem is it is still plowing. The hull is running way to wet(3/4 of the hull in the water).I am going to ad a few nylon spacers to the prop shaft between the universal and the out drive and ad a shim between the hull and the drive to angle the prop up a bit more.Hopefully this will get it to ride right. If not ill try to ad some weight in the transom area.
    Apr 2010
    3,480
    Move the COG back to 4" and it should help stop the plowing.
    Cool, glad it helped. =)
    Nov 2009
    Ca
    2,686
    Be careful. Running that esc at 60% throttle is transferring that other 40% into heat in the speed control. It could cause the esc to burn up.
    Mar 2011
    ma
    756
    I'm running a mongoose 8.5 6000kv sensored with a 40mm prop. On 2s it won't flip on 3 if I'm gentle out of the whole its pretty good but way too much power for that little boat
