Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
Thread: Water Pump.
  1. #31
    4,100
    There are a couple newer threads about cooling pumps. I use the TCS micro pumps in most of my FE boats now and have bought some of the cheap 6V and 12V pumps off Amazon but only bench tested them.
    Where do you source the TCS pumps from?
  2. #32
    Oct 2020
    ZH
    50
    Maybe direct? Which TCS do you prefer? And why? Is the self-priming version necessary? Thanks
    Verzonden vanaf mijn iPhone met Tapatalk
  3. #33
    Sep 2007
    2,778
    I prefer the M200 pumps. I have the M400 and M410, but they don't seem to work as well as the smaller pumps.
    They do have a geared version, but it is quite expensive. I like the M series as you can push water through them using the normal pickup and if the flow drops due to boat speed reducing the pump starts to push the extra water through.
    I have bought the pumps directly from the UK in the past, but they now have a US distributor. https://www.servoflo.com/micropumps/...m200-micropump
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
  4. #34
    Oct 2020
    ZH
    50
    Thanks man. Have you tested the self priming ones?
  5. #35
    Sep 2007
    2,778
    Yes, I have one of the MG2000 pumps from TCS. It works great, but cannot flow through like the smaller impeller pumps. I had to build a bypass system with a one way valve to allow flow around the pump when not on and when the pump is on, the one way valve prevents recirculation. It would be better suited for the large cat's and mono's where room and weight are not an issue.
    Tyler Garrard
  6. #36
    Oct 2020
    ZH
    50
    Ok thanks. The m200 are very low voltage right? Extra power feed? Or do you power it from your receiver?
  7. #37
    Sep 2007
    2,778
    Yes, 1.5V and 3V. I use the 3V versions and a DC step down regulator from Pololu.
    https://www.getfpv.com/pololu-3-3v-5...regulator.html
    I just run the regulator off the BEC power.
    Tyler Garrard
