Originally Posted by
Fluid
Before you spend money on a "good deal", think about the total cost of the project and the performance you want. Those motors are cheap, but you will need to buy all new hardware, two props, two ESCs, two motor mounts, and more cells. Suddenly those cheap motors are not so cheap. And more importantly, will they give you the performance you want? If not you'll have to buy new motors.....
If it were me I'd go with the single motor option. Then you can spend more on a better quality ESC rather than two cheaper ones. You really need 10S to get the speed you want with reliability. A cheap motor and cells won't get you to 65 mph. You could try one of the Scorpion 4035s and maybe get close to 60 on 10S1P, but exceeding 65 will require 2P and a better motor if you want reliability. For a couple of SAW passes you may be able to prop up enough to get there, but not if you want much run time.
Bottom line - make sure you think this big project through before spending any money, or you'll have to spend some of it twice.
I couldn't agree with Fluid more.
The 4030's are powerful, but IDK about enough to push a 42" twincat at those speeds. They'll push it, but it's going to take a lot of watts for that big hull.
You still have time to change your mind on the motors. They are an easy sell, so no harm done.
FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
