Page 2 of 2 FirstFirst 12
Results 31 to 41 of 41
Thread: NUE Power on 4S
  1. #31
    2,686
    Quote Originally Posted by JEDNJONES View Post
    Jesse, Do you have anything laying around that would get my boat back in the water?
    What parts do you need?
  2. #32
    Aug 2008
    7,080
    um well Jed, I do have a brand new flex line 1/8" to 4mm that came with that MHZ hardware. I was able to salvage the ruined one I got from Brad in my MHZ Fountain. So I do have this flex that I ran in my P1 before gutting, so I know it is long enough. I was hoping to hang onto it - but due to ponds' eminent freeze, I think I could spare it if it gets you back on the water.
    I could let you have it for $20 shipped. No drive dog - but can include liner if you need.
    Other than that, I have nothing with 4mm stub.
    "Look good doin' it"
    See the fleet
  3. #33
    Aug 2008
    7,080
    If my inline set up doesn't work, I was considering going the traditional offset route. In that case I was looking at either speedmaster stinger strut and rudder or something similar. I was thinking that since this hull is prone to lift in headwinds, a more set back prop might help (i.e. the stinger or my fabrication). That would also get you back to .150" flex, 3/16" stub and a simpler life
    See the fleet
  4. #34
    Apr 2010
    134
    Forscott, at this point im waiting for Jeff to build me a wire drive. In the meantime ill buy anything that will be a direct replacement for the 4mm flex that I broke.
    Fountain KOS P1, Formula Fastech, 37 Fightercat Daytona CF twin
    Pulled by Slash 4x4 tow vehical
  5. #35
    Apr 2010
    134
    Jesse, Only if you dont mind parting with it. I assume I would be able to use the stock drive dog? Also, would I need a different motor coupler or will the 1/8 fit? And, yes I would need the liner.
    Jerry
  6. #36
    Sep 2010
    91
    JEDJONES - I will get yeah on the next poker run pending the water conditions. Its to hard to run with you in rough water. Beware of my new Jolly Cat that I will be running at the next event.
  7. #37
    Apr 2010
    134
    I wouldnt be suprised turbo. You always beat me. Even on my own motocross track.
  8. #38
    Aug 2008
    7,080
    yes, I used the stock drive dog on the new flex - its identical, I even ground off a flat spot for drive doggy to sink his teeth into. Being a 1/8" I should be able to fit it into a small flat rate box. Like I said, I don't mind if it will get you back on the water, hopefully for the weekend. If you pay as a gift (si senyor) then pm me your physical address. I will pop her in the mail tomorrow morning.
    paypal is geohead73@hotmail.com
    See the fleet
  9. #39
    Apr 2010
    134
    Thanks Jesse. You have PP. I just couldnt find a long enough 4mm one to pop in anywhere besiseds hongkong. Ill use it temporary until I upgrade the drive system. So, you could have it back too if you want.
  10. #40
    Aug 2008
    7,080
    need your physical address, don't think I have it still.
    See the fleet
  11. #41
    Apr 2010
    134
    Jesse, You have PM
    Thanks for the help!
