Hi, I am getting ready to rework the Triton. I was just wondering what motor I should put in it? I will be using 14 IB4200's and a Pulso 100 amp ESC. Just sport running. Hoping to get in the mid to high 40's or faster if possible. Thanks
9 or a 10XL will get you there.
Doug
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
I have the same question but for only 12 cells at present, lipos in the future.
How would an 8XL go ?
Graham.
An 8xl is too hot for the triton hull, even with the weight saving of lipo. 9xl is great on 5s lipo , and I think 10 with a 47-50mm prop would be good to. I run mine 9xl ,5s and m447 @ 50+ mph.
Because I have lashed out and bought 2 8XLs and Hydra ESCs for my Jolly I was hoping to be able to 'borrow' one for the Triton.
If I kept the prop size down to say an X440 or 42 and use only 12 cells do you think it would survive ?
Graham
No I dont! Have tried a 8xl on x442 and lipo and I melted the 5.5 mm plugs off. This was on 5s though, lower voltage mite be OK, one thing though the triton hull needs a larger thrust cone than the 42 mm can offer it will cavitate like mad getting going. 14 sub c and the 9xl with a m445 is a good start. Mine runs 53-55mph with a 5s and m447, and 50-52 mph with a m445. The m445 handles better with less prop walk. The m447 can make it do a 360 deg barrel roll at 50mph over a wake. It is the boat in my avatar and whilst I agree with others that there are better handiling hulls the self righting of this hull makes up for that and they are SO strong. My hull has been driven over and hit a wall at about 45 and has NO damage other than a few scratches. You will need trim tabs at these speeds and a good turn fin.
It has been done with those props on a well set up Triton Graham. I would be more concerned about the cells than the motor. Keep the runtime short so you don't dump the cells.
A club member raced that setup for several weeks on 4s while waiting on a Neu motor.It ran pretty close to the 1515 1y. (The motor was water cooled)
Doug
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
