Results 1 to 18 of 18
Thread: UL-1 air dam ???????
Hybrid View
    Jul 2010
    AR
    88
    Default UL-1 air dam ???????
    Can someone show me a picture of a air dam on a UL-1 or similar? Not sure what or how or where it should go. Thanks.
    Stringfly <>++++
    Oct 2009
    NC
    4,204
    Quote Originally Posted by stringfly View Post
    Stringfly <>++++
    http://kintecracing.com/UL-1_Upgrades.html
    Scroll down. Or you can make one out of tape. Position you gonna have to play with. Should go between the sponsons on the bottom of hull.
    - Diesel's Youtube
    - Diesel's Fleet
    Nov 2009
    WA
    2,038
    Do a search using " UL-1 air dam" on OSE and RRR and your going to get some good info. Here's the basics for the UL1.
    Seems you can use pool noodle cut to shape like the "L" shaped plastics we see being used. You dont have to buy anything from anyone to get the right materials. Go down to your local home depot/ eagle hardware/ whatever and get a 7" long, 1/2" by 1/2" plastic/lexan "L" shaped corner/ edge protector or if they have aluminum angle stock buy a 1 foot piece. Use some double surface foam tape or even just use hatch tape and put it in place. It needs to be approx 2 1/2" behind the leading edge of the sponson bridge or center section depending on how you define that part of the hull.
    I have tested and found that a 3/8" x 3/8" works as well if not better then the 1/2" stock. But it seems more folks have added comment using the 1/2" material and I am not going to debate the size. Use what you like. It turbulates the trapped air and keeps the hull from lifting. Just like the wing of an aircraft. Something this simple can add more then 10mph on your top end.
    John
    Change is the one Constant
    Wa
    5,905
    Go to the hardware store and get the clear plastic edge trim for sheetrock corners and trim it down to whatever you want
    Billy Graham
    Jul 2010
    AR
    88
    Thanks everyone. That helps a bunch.
    Stringfly <>+++++
    Sep 2010
    CA
    5
    can anybody post an image of the air dam installed?
    May 2010
    693
    Quote Originally Posted by bg555 View Post
    Not mine but you get the idea. Should be about 1.5 - 2 inches from the front edge, mounted as shown.
    May 2010
    fl
    146
    would this be a good upgrade for stock configuration or only hotter setups
    Mar 2011
    KS
    70
    another pic
    May 2011
    sa
    179
    Default Air Dam
    On my UL1 i found as soon as i started getting over about 45 mph with the bigger pitch props like m445 / m545 it was needed big time
    Dec 2010
    CA
    65
    Quote Originally Posted by Wade View Post
    another pic
    Wade do you notice any difference is it working no more wobble ?
    Mar 2011
    KS
    70
    Quote Originally Posted by mavdriver View Post
    I still get a little wobble but I still have yet to run it without some/little chop. I do notice that it keeps the nose down a little but I also experimented with battery placment/etc to help with this and to also get it to plane without always "gunning" it.
    Dec 2010
    CA
    65
    Got it thanks for the quick reply will be trying it tomorrow see what my UL will do over all it runs good .
    Jun 2011
    ny
    152
    i wonder if this would help me keep the deuce planted esp when running into the wind she gets real light around 53 mph
    Dec 2010
    CA
    65
    I try it I dint like it felt like it was slowing down thats my take on it IMHO
  16. #16
    Jun 2011
    ny
    152
    what if you changed angle from 90 and started bending it back twords 45 a little by little?
  17. #17
    Nov 2009
    CA
    1,969
    I just tape a drinking straw across the full length of the tunnel to my shovelnose hydro and it makes a huge difference keeping her on the water.
    Chief
    Sent from my XT890 using Tapatalk 2
  18. #18
    Jul 2013
    Fl
    380
    Quote Originally Posted by BHChieftain View Post
    Chief
    Hey Chief, could you post a pic of the straw installed? Thanks. I am thinking about using a small dia. carbon fiber tube.
