My Word..........!
What a Monster.............just got my 1717 in...........the sheer size and weight of it is truly impressive.........makes my Feigao 580L feel light.............and small........especially with its can fins.
Got my 1520! Big motor! But still small in comparison to the leopard 5692.
Darin E. Jordan - Renton, WA
The 1518 is a work horse. 68mph in my 36" tunnel w/ hydra 240lv on 5s2p set up for heat racing. I got 3 of the 1520's and 2 of the 1717's. I think the 1717 will push and 1/8th scale just fine, its just the kv being so high that has me a little nervous. Either way, the price of those motors, you would be crazy not to stock up. You can get the bigger ones, overpower your setups and run a smaller prop to keep temps down. I don't even know what I will use mine on yet! haha, Mike
A set of Castle 1520-1600KV will be perfect for a twin setup in the MHZ Mystic medium 114cm, 6S for each combo
I' m interested by a Castle 1717 for a mono hull like MHZ Racemaster 987mm - 38,85", do you think that 6S is sufficient?
That's a sweet looking mono!
I gots mine too...
I got a 1512, 1518, 1520, and the 1717... one of each... I am gonna overpower my mean machine with the 1717... change out the 9xl in my df29 to the 1512, and I may use the 1518 or the 1520 in my (rumdogs old) phil thomas stealth... as it currently has a 4074 leopard....
The 1512 is the one with the cooling coil on top of the box... its the only one I didn't order a OSE cooling can for... does anyone know if a 1515 cooler will fit or will it be to long?
yeah!
problem is, this is only half what I ordered
the woman at Castle said they made a mistake and will ship the other two by Monday!!
She also told me they are having orders of 300 per day
and they have hired temps to help with the orders
It will fit if you notch it for the wire plug coming out of the can. I have one for the 1515 can, but thats been modified that came off a 1512. Worked great. You only need to file a notch about 3/32 deep. You just need to be sure that with the o-rings on the can seals well. Trust me. If it slides over the first o-ring tightly then it is the right size. If it slides over the first o-ring with little resistance the jacket is the wrong size unless you have different size o-rings.
John
Change is the one Constant
Its good to know I'm not alone in my motor fetish... :p
Just a little heads up
Castle is making a Baja Gas to 8s-10s Brushless conversion and with it comes a new CC2228 750kv motor
they don't have pricing on just the motor, but that could be a sweet boat motor for the big ones!
I' ve got my CC 1717, with water jacket What a monster!!
