Uhhhh.....you haven't given us enough information here.
- How many and what kind of cells will you be using?
- What motor will you be running (diameter, turns/Kv)?
- What kind of performance are you looking for?
- How much run time are you expecting?
- What is your budget?
Depending on the motor you use, this may work well:
http://www.offshoreelectrics.com/pro...rod=dh-prb2314
Most brushless ESCS can't run a brushed motor - except for those gold-plated Teutonic wonders which cost $700US.
Prop size depends on the motor you choose and the voltage you use, not on what someone else said.
