Results 1 to 4 of 4
Thread: Hobbywing ESC Programming card faceplate
    Apr 2010
    3,480
    Default Hobbywing ESC Programming card faceplate
    NOTE* If you use a hobbywing programming card, check to make sure it has the right faceplate. The cards are interchangeable, but the options are different.
    There are three different faces for the programming cards.
    http://www.hobbywing.com/english/Art...?ArticleID=435
    Platnum AirCraft/Heli:
    EZ Run Car:
    Boat ESC:
    After watching an outrunner glow red, I realized that my programming card had the WRONG faceplate and I was setting the timing at 0 instead of the punch control at 1. Nowhere in the instructions had this explanation and the card came with a boat ESC. Some Hobbywing dealers are shipping the wrong faceplates on the "combo deals".
    (OSE has the correct faceplate)
    So if you use a programming card from an airplane, heli or car esc, check the faceplate for the correct values/info.
    FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
    Sep 2009
    HI
    1,679
    OR you can follow the flow chart on the esc manual. I just carry it in my tool box. I use the same box for my trucks too.
    Apr 2010
    3,480
    Quote Originally Posted by BakedMopar View Post
    Yep. =)
    Attached Files Attached Files
    Jul 2014
    3
    Seaking 130A - HV ESC programming manual is here.
    1. program with your transmitter
    2. program with a hobbywing program card. (see under troubleshoot section)
    http://www.falconsekido.com/collecti...king-v3-manual
    hope this helps.
