Results 1 to 7 of 7
Thread: anyone running 2030 ul-1 motor in supervee? best prop?
    Mar 2010
    MA
    3,573
    Default anyone running 2030 ul-1 motor in supervee? best prop?
    as the title says. i got octura 440/2 and grim 40/52/3 props. which is better for this application
    Mar 2010
    MA
    3,573
    i really need to lurk forums first. diesel has video. looks pretty fast. ill try both props i guess
    4,204
    Quote Originally Posted by dana View Post
    Ran 47mph with a 42x55 and a good current, settled at 44mph-45mph with the same prop. Also had a 7xl with a aquastar 120 run 53mph on 4s http://www.youtube.com/watch?v=6JSwz6hiRwc the grim 42x55 is the fastest prop Ive used on a sv.
    - Diesel's Youtube
    - Diesel's Fleet
    Aug 2010
    on
    760
    42x55 all the way
    Mar 2010
    MA
    3,573
    im currently using x440/2 and honestly i can barely keep the boat in the water
    4,204
    You may be running too loose. The bow should run just barely out the water, check my vid on 4s in my signature. Boat never gets out of shape and runs 105-110F temps also that is with a 42x55 prop at 47mph (nice current, normally runs mid 40s). The boat is very slightly trimmed negative and the rudder is rounded and tucked to dump excess lift.
    - Diesel's Youtube
    - Diesel's Fleet
    Oct 2010
    AB
    2
    Cool SV best prop
    Try an X-642 . Its the biggest prop that won't over heat anything. It gets you up on plane instantly.
    NeilsSV
