Results 1 to 2 of 2
Thread: Stiletto steering
    Sep 2010
    42
    Default Stiletto steering
    I have looked at the Stiletto steering a couple of times at the store. Is the main reason the steering servo is in front is to allow more room for fitting the batteries in? The issue I have, at least from viewing the one in the store, is that the cables rub on both the ends of the battery/esc compartment.
    Still a nice looking tunnel.
    Thanks, Steve
    WA
    8,335
    Quote Originally Posted by voepel View Post
    Once the lower unit is setup properly, there is room on the steering shaft at the back to move the steering arm up to get the cables off of the cover.
    I've raced mine all season with the cables rubbing on the cover, however. Not a big deal. It's just how these systems work sometimes.
    With the servo in the back, motor adjustments affect the angle on the steering arms a lot more. Also, it's harder to get the boat to balance properly, and not as easy to isolate the main electronics from the battery tray and keep them dry.
    Darin E. Jordan - Renton, WA
