Results 1 to 5 of 5
Thread: Turnigy 90A esc programming help!!!
    Jun 2009
    1,177
    Default Turnigy 90A esc programming help!!!
    Tried the manual Tx procedure and many others but throttle doesn`t hold right.I have a Tactic 2.4 Tx/Rx.HK even doesn`t recommend ussing the manual Tx programming.Anyone here have done it sucessfully? or do i really need to get me their programming card?.....Thanks,...Al
    Jun 2010
    90
    I had some issues with mine but I re bound the rx and problem solved programmed no problem.
    Jun 2009
    1,177
    What you mean by rebounding the receiver? can you explain a little more?..thanks fpr replying .........Al
    Mar 2010
    ME
    3,438
    push and hold the bind button on the rxr while you turn on the transmitter.... well I think thats how i remember binding the tactics.... pretty darn sure anyway.
    Jun 2009
    1,177
    Just in case,my problem is not binding the Rx with the Tx.Its getting the esc to work properly.
    So in doing so as you explained here i`m guessing packs should be connected first.Then press the tactic binding button and then turn on the transmiter?...did i get it right?...thanks,...Al
