Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: seaking 180 esc not working...HELP!!
    Jul 2010
    fl
    656
    Default seaking 180 esc not working...HELP!!Returned
    new esc and its not doing its thing.
    all i'm getting is a beep beep etc and a red flashing light.
    steering is working but no throttle.
    freshly charged battery and i have the program card.
    i am stumped.
    thanks in advance
    ian
    May 2009
    3,180
    Did you calibrate with your radio?
    DJI Drone Advanced Pilot
    Canada
    Jul 2010
    fl
    656
    if you mean holding throttle on full while connecting power, yes.
    I have even tried a different motor.I have other smaller seakings and this is the first problem
    i've had.
    I cant get the program card to work with either.
    I really appreciate your help.
    WA
    2,038
    What battery are you using? 2S? 6S?
    John
    Change is the one Constant
    Jul 2010
    fl
    656
    4s lipo fully charged.
    I have the dx3 tx.
    The 180 is beeping and the motor is twitching as it beeps.
    If that makes sense....lol
    Sep 2009
    HI
    1,679
    Yes that usually happens when you connect power but have no radio signal. When holding the throttle open on start up are you returning to neutral while its still beeping? I'm going to assume your using the internal BEC, which means power is getting through it and powering your reciever. Try re-binding your tx to you rx and try setting the throttle perameters again.
    BTW make double sure your esc is plugged into the correct port and the right way into your rx. Iv'e made that mistake a few times myself.
    Jul 2010
    fl
    656
    i've tried everything i normally do.
    re bind etc.
    I have installed new esc's before bit this is new problem for me.
    The red light on the esc flashes and the motor twitches even when its not plugged in to the rx.
    I have also tried another rx.
    Looks like its a paper weight or is the 180 different to my 120 and 35amp seakings?
    thanks again
    Sep 2009
    HI
    1,679
    Quote Originally Posted by britscoot View Post
    re bind etc.
    thanks again
    Did you try reversing the throttle channel?
    May 2008
    1,744
    Quote Originally Posted by BakedMopar View Post
    Try this. I bet that is it.
    Sep 2009
    TN
    1,598
    I had a similar problem one time when my esc was programmed for a higher voltage. If the input voltage is not high enough it won't do anything but blink blink blink.
    FE BOATING: Less like a hobby and more like an addiction!
    Nov 2007
    6,927
    Don't use the auto-detect setting for lipos. Manually set it for the number of cells you are using.
    Mini Cat Racing USA
    www.minicatracingusa.com
    Jul 2010
    fl
    656
    all i have is a red flashing light and the motor twitches.
    I tried using the program card but got nothing.
    reversed the tx etc.
    this really sux.
    Jul 2010
    fl
    656
    if its not working with the program card it must be f'ed?
    I just hooked up the card to my seaking 120 no problem.
    what are your thoughts?
    Nov 2007
    6,927
    The motor twitches because that is where the sound comes from!
    Mini Cat Racing USA
    Jul 2010
    fl
    656
    i just tried different voltage and still nothing.
    I still dont understand why it wont work with the program card.
    Hobbywings website isnt really helpful either.
    I emailed them once regarding another esc problem i was having and got no response.
    Guess you get what you pay for.
    Nov 2008
    Ql
    3,169
    Have you tried moving your throttle trim down or up. That some times is the problem. It's not reading zero on the TX. It's happened to me.
    Cheers
    Paul.
    Aug 2010
    Fl
    50
    my swordfish was doing the same thing twitching, these are all made by hefei? look down at my thread ''any swordfish 240 hv users'' I tried everything then 'disar' posted to set my throttle trim 25% B and hold until it beeps 4 times then go to nuetral it worked!!
    Jul 2010
    fl
    656
    Yeah tried almost everything!
    Its only futabas that require rev throttle.I tried it anyways.
    I'm using spektrum dx3 tx and a mr200 rx which work well with my other seakings.
    My brain hurts now and i have to admit defeat.
    Jul 2010
    fl
    656
    i still think if its NOT working with the program card its got a major problem.
    I hate this esc....lol
    thanks for trying guys!
    May 2010
    OZ
    74
    Have you tried a different motor? You could also disconnect the motor from the esc, leave it for 5 minutes or so then reconnect & redo the calibration. Is this a DX3S transmitter you are using?
    I'm running the same esc with a dX3s & have no issue. Be sure that your ESC receiver plug is plugged in the right way round. What is the receiver doing? is the light steady or flashing?
    Jul 2010
    fl
    656
    i have tried a lot of different combinations,motors,rx etc
    Using the DX3e with other esc's no problem.The tx is bound to the rx and the steering works.
    So the esc is providing power to the rx but all i'm getting is a green flashing light.
    Did i mention i hate this esc for giving me grief.
    Nov 2007
    6,927
    Sounds like you should try a different motor as Simo71 suggests.
    Mini Cat Racing USA
    Jul 2010
    fl
    656
    things i have tried.
    different motors,rx's, battery voltage etc.
    I must correct my previous post,i'm getting a RED flashing light,NOT GREEN.
    when i connect it to the program card,nothing on the card lights up.
    This esc has won!
    I hate to give up though.
    Nov 2007
    6,927
    Bummer
    Mini Cat Racing USA
    May 2010
    OZ
    74
    Did you go over the things I mentioned? With that radio you need to check all your switches are in the correct place. The 180's are a good ESC, perhaps you could try another ESC from some where else & see if motor etc operates as normal.
    Also what slot are you using on the program card?
    Jan 2010
    891
    This esc has won!
    britscoot, it is time to end this frustration, shipped in four days from OSE, an ETTI 150.....these puppies are precious. BG
    Jul 2010
    fl
    656
    i have the seaking 120 also and had no problems with my DX3e.
    I didnt have a problem setting that one up.
    If you have to jump through hoops to get an esc to work,then its not for me.
    All you should have to do is program and go.
    I am using the right hand slot on the card as per the instructions but nothing lights up.
    I just think i have a bad unit.
    Sep 2009
    HI
    1,679
    With a light tester make sure the white wire is sending signal. Check that it's not pinched or frayed.
    Jul 2010
    fl
    656
    I just finally heard back from the place i got it and they are going to exchange it.
    Thanks guys for trying to put me out of my misery.
    Your the best!
    May 2007
    no
    415
    Your the best!
    nice...
    where did you buy it ???
    good luck with the replacement
