Originally Posted by
shotimes95
So is it wise to not run my boat with the original shaft? And what exactly is the issue?
There is a potential that the cable will, when put under shock/stress, try to unwrap the outter layer, putting it into compression, as opposed to tension. This would cause additional drag, and potentially a seizing up in the stuffing tube.
I think if you run using the stock prop, and be a little gentle with the accelleration and try not to shock the driveline too much, you should be fine until the replacement cables arrive.
Darin E. Jordan - Renton, WA
