this is why I don't order/buy anything that has just been released to the market.
This isn't a holiday weekend for everybody on the planet.
We'll be making good on this. If you can't wait, the drive is standard .150" cable with a 3/16" stub. We wanted to make sure everybody could use standard parts, and it looks like that will pan out for you die-hards.
Details will be out next week.
Andy
Spektrum Development Team
Looks like OSE is coming to your rescue already! Way to go, Steve!
https://forums.offshoreelectrics.com/...304#post225304
Have fun testing!
Andy
Steve, once again, you are the man!!
This is a minor issue compared to the, first GEN UL1 with the turn fin problem , but we all still brought them !!! i own a few Pro boats & think they are well made , looks like steven flex sales will go thru the roof LOL . Like a few others i like to make my own shafts with the ends Loctited on cause they dont fall off like the solder ones !!!
Good catch !! but i think this wont put me off buying a Geico, just my 2 cents worth
UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
The hull is a beautiful yellow and is a lot better built than the BJ26. I have tons of counter rotation props too......I can still run her either way!!!!
For someone that can glue a cable, cut the flex and solder. Its a cheap $10.99 fix.
A regular Octura .150 cable with 3/16" shaft will fit
http://www.offshoreelectrics.com/pro...oct-oc150L-24c
Steven Vaccaro
Darin,
The HH technician I talked to tonight was extremely sheepish and felt very bad. I agree that it is a bonehead mistake but on balance it is a very minor thing compared to how awesome the boat is. I will order a new one from Steveo and wait for my stock replacement as well. Heck, if something was going to happen to the boat I would rather have this happen instead of the ESC exploding and marring that beautiful hull!
yup mine is reversed as well.
For those of you thinking of installing dual motors, there is going to be a large supply of counter-rotating cables.
I will give all the details of getting replacement parts form ProBoat as soon as they have it all solidified. They are working on it as I type, and the manufacturer is working on getting a supply of replacements.
I was told that the new boats in stock, once the replacement is available, will be packaged with the replacement shaft and instructions/tech note inside the box.
The bad news is that it's likely going to a few weeks at least before they have them ready and here to distribute.
Darin E. Jordan - Renton, WA
Sign me up, my flex is clockwise instead of counter-clock. I will shot HH a email tomorrow. Looks like this went viral, O well this isn't a major deal for us guys. Maybe new boaters who have no clue, that could be an issue. I had a extra hyperformence cable laying around .150 3/16. It is about 1/8 inch shorter than the stock flex, hopefully it works.
I contacted HH this morning. The person I spoke to wasn't aware of the issue, but they put a flexshaft on order for me.
If this is the only issue then not too bad but a silly mistake on their part. Sounds like the stub may be a bit longer than an Octura 2.25" If the Octura will work as Steven says then not a problem. If the stubs need to be longer then we can make those as well.
Sucks but worse thigns can happen so hang in there.
What are the specs...total length and stub length only?
Wonder how the 078 wire drive will work in this? Should be easy.
Mine is also backwards.
Also got from HH
We're pretty sure they're ALL backwards. They put a hold on everything so nothing more will ship wrong.
Andy
I just picked one up today at my local HS today. WHY DID'NT HH TELL THEM THERE WAS A PROBLEM. I'll fly heli's tomorrow. Next time before I by a new boat I'll go to OSE first. It does look good.
I cut down a UL-1 cable, took 10 minutes and works perfect....
I just want to thank everyone for the warning and the info on the UL-1 shaft .
Andy,
Any word on when we can expect the new "warrantied" flex shafts?
As of about 9:00 today we didn't have a ship date.
Andy
Andy,
Were you expecting them to ship already this week? That would be a quick turnaround.
I ran into a interesting thing the other day when I was going to remove and change out the motor couple. The set screw had loc-tite on it (good), but was stripped (bad). I tried both metric & stanard keys, but no luck. I even tried some valve grinding compound which we use in aviation to help grip semi-stripped screws planes, but nothing. O well, it's on their good and works so I'll leave it. I will drill it out if I ever want to change it. Just thought I would mention that. All in all I LOVE THIS BOAT!!!
