Yes
Yes
I put some clear silicone in those holes on mine, then pressed it in with the dowls. I'm not sure if they are totally sealed or not from the factory. They should be, but ???
I also sealed around all of the water lines on mine, and around the wires. They pass through double-hull sections, so if any water gets past them, it can get down inside the hull.
Mine stays dry inside now.
Darin E. Jordan - Renton, WA
Oh well, I knew this was going to happen... I chipped the gelcoat on the tip of the left sponson.
Don't ask me how since I have NO idea, I didn't see the missing gelcoat when I got her out of the car, so I must have hit something at home.
I'll try to get some supply at a local marine supply store. Any suggestions for a gelcoat repair kit? Should I use just gelcoat paste? Or epoxy? What about color matching?
It's a small chip, about the size of a small bean.
Thanks.
man, I wish this would bind to a DX6i
Darin, can you confirm the preset throttle curve for the ESC?
I've never heard of one being preset to the logarithm mode. In fact, I've never even used one in that mode. I can ask, but I'm certain it does NOT come pre-programmed in that mode. Should be linear.
I have noticed that the "steps" in the ESC are pretty large. Running at full throttle, then lightly backing off, results in a pretty decent drop in throttle. Typical RTR throttle curve.
Darin, I ordered a programing card for my new Stiletto. What do you recomend for settings? Thanks for the silicone tip. My other question is about the ESC. Factory setting set for beginner mode. 80% full throttle?
Thanks, I'll try that
ALD... I really don't think that "beginner mode" is necessary for most people... in fact, on a tunnel, it may make it tough to balance the boat in the turns.
For the Stiletto, on the stock setup, I'd set the programming like this:
Battery Type: Lipo (assuming you are using Lipos)
Cutoff Voltage: LOW
Cutoff Type: Slow Down
Brake: OFF
Timing: LOW
Throttle Curve: LINEAR
Try that and get used to running the boat. If your temps are good and all is happy, then you can try the HIGH timing setting, which MIGHT (jury is still out with this boat) give you a little more zip...
Here is the damage (if anyone cares).
I'm a very sad panda...
had first run on smooth water.....ran great but no 40 mph for sure..... still needs motor angle and hight adjusted to a better position.....darin can u take a pic of your motor hight mounting screws pls and the angle of the motor? that would really help me......funny thing happened to me as i flipped the boat powering it up across its own wake......current going out....its a swim or just wait for it situation....i pull the throttle and the prop is touching the water and i power it in(about 20yds upside down...now i know it didnt do the motor any good underwater but will oil the barrings etc and hopefully it will be fine as i ran it for 5 mins after that and ran fine.....
will these take full speed turns?
In stock trim, certainly... flies through the turns...
When you start proping up, and get it up to race speeds, you have to do a little more balancing in the turns. Basically, ease off a tad to set it into the turn, then squeeze it back to full throttle, easing off here and there if it starts "flying" in the turn (pushing to the outside).
That's just been my experience thus far, but mine is still not quite dialed in to a comfortable place for me to drive it. Also, that's a description of trying to drive a race-course, with 35' radius turns, holding lane one. If you turn a little wider, you can flat-out it. What can happen, however, is if you set it down too hard entering the turn, and try to add too much steering input too quickly, it can grab the outside sponson and tumble/roll to the outside.
Takes a little setup, timing and finisse to get it just right, which is part of the fun, and frustration, of driving tunnels...
I think thats why people enjoy racing tunnels so much. Watch some footage of the F1's (1:1) & they have the same response if a driver is being over aggressive when entering a turn etc.
Darin has giving a great answer about full speed turns with an O/B tunnel hull. This hull or any other O/B tunnel hull requires you to DRIVE the boat. This hull type isn't like most others where you can "throw" it in to a corner and expect it to sling shot around with out upsetting the hull. Racing these hulls WILL teach you how to manage your throttle thru the turns and teach you how to set up a boat. If your set up is a little off you will know it. However, once you hit that sweet spot.... man-o-man these tunnel hulls are a blast to drive and race...
Later,
Mike
Ok folks. I have made several runs with the stiletto and found that this boat instock form can not due 40mph. Without a GPS I would guess at around 30mph. Being fairly new to boats and tunnels this speed is perfect to learn how to drive a tunnel. Anything faster at this point for me, would be frustrating. Spin outs in turns etc. I re-programed the ESC and calibrated my DX3s. This boat is so much fun to drive and learn at a relaxing speed. I'm sure in time, I will upgrade motor/esc/ prop for speed, but for now, great boat and lots of fun!!!!!!!!!! Test made using 4s 2pack 5300 25C lip"s.
When I ran it last weekend I noticed mine was a little slow as well, but I thought I didn't set the motor angle properly. That was with an X440, I haven't tried the stock prop.
I just finished applying the first layer of gelcoat to mine, hopefully it will be ready for Sunday!
BTW, I've found other areas of the sponson where the gelcoat is slightly raised and if I gently press on it it flexes, I guess it didn't adhere completely to the fiberglass, I wouldn't be surprised if other cracks were to 'magically' appear on those spots.
Something to check on your Stilettos I guess.
Tunnel boats are very hard to setup. I just received my Stiletto and looks very well built. I was not looking for the fastest boat on the planet, just a very cool looking F1 tunnel with what appears is a neat outboard power source and not some apendage that is but ugly.
Douggie
Yes, it is a very cool looking boat. I trimmed mine according to the instructions. I tried trimming the motor up (away from transom) a little and that was a huge mistake. boat fliped and very unstable.Taking awhile to learn how to drive. I added a lot of expo and cut the travel down on steering and I find that setup to be very forgiving. I use 4s lipo 2pack so unable to adj cog. I think a4s lipo single pack would be a better fit for adjusment.
Great looking boat can't get it to go more than 35mph on a single 45c 4s pack,may try 5s but don't want to burn anything out.There is no way to get over 40mph on this boat unless you change out the electronics.I have tried everything!
If it can keep up with a VS-1 with modified legs and apparently it does, it is fast. Speed, stability and handling are all relative
Douggie
i think if mine had gelcoat blisters and chips comeing off id be on the phone to horizon right away for a new hull...it wont get better only worse with blisters....
There were some minor scratches around the area, I believe I did scratch it and that made the blister break and the gelcoat come out. The fiberglass under the chip looked nice and clean.
I've fixed it now and I'll be more careful, if any more gelcoat comes off without reason I'll contact them and see what they can do.
I was just wondering if any of you guys have noticed any "blisters" on theirs.
