Results 1 to 5 of 5
Thread: Miss Geico run time
    Jun 2010
    LA
    47
    Default Miss Geico run time
    I ran my Miss Geico for the first time today with flightmax 5800mah batteries. I got about 7 minutes runtime before hitting lvc. Is this about right?
    4,204
    Quote Originally Posted by kevink View Post
    7 minutes is a VERY long time. Cut your run time down and avoid hitting the LVC. It is not good on the batteries to rely on the lvc every time. Aim for 3-5 minute runs times. Your electronics and batteries will last a longer if you time your runs, monitor your tempertures and always grease the flex shaft every 3-5 runs at a minium. Happy boating.
    - Diesel's Youtube
    - Diesel's Fleet
    Wa
    5,905
    sounds like you ran it too long to me unless you like to replace gear or batteries fairly frequently
    Billy Graham
    Jun 2010
    LA
    47
    Default Runtime
    Thanks a bunch guys. I'm learning a lot on this site. Learning that fast electrics are much tougher on electronics and more sensitive to setup than cars or helis. I'm now addicted to RC boats.
    Cool
    That's around 55 amps average draw, which can create a lot of heat over seven minutes. Get a IR meter and measure the heat of the motor, ESC and cells.
    Even if the temperatures are not excessive - over 140F on the cells - hitting a 3 volt LVC is not good for the cells. The 80% rule is a good guideline - use no more than 80% of cell capacity. This means you want to use no more than 4500 mAh to bring the cells back to full charge after a run.
