That is weird. There must be something unique about your MG for it not to response to any of your adjustments. I too have played around with battery placement, and shaft angle adjustments, and found a noticeable differences in the trim of the boat with the different battery positions. If they were to far in one direction or another, the boat would be either too loose, or bow heavy.
The boat has enough power to attain full plain regardless of the battery location, but if I put the batteries to far forward, and if it had diving planes on it, the darn thing might submerge. Perhaps I exaggerate, but just to make a point.
I don't see huge differences with shaft adjustments at this point, but I have not done but two changes. I did notice a slight trim change.
For my first tests, I used an original version, Kintec Racing ruddder offset kit, which improved the boats ride, but at the expense of adding lots of drag at lower speeds, and in turns, not to mention the dragging portion of the bracket creating a water spout or geyser style rooster tail until the boat achieved full plane. Actually, it looked kind of cool
I just received and installed the next generation Kintec bracket with the lower part of the bracket machined out. I am sure that will make marked improvement across the board. I will know for sure this weekend, if the weather permits testing. (see the pictue below)
It is interesting how your boat is able to defy physics, very strange. It might be interesting to weight it, and compare that to the weight of other MGs. Maybe your boat has a heavier lay-up?? A heavier boat might influence the boats behavior to the point that it is not sensitive to the changes you made. Just trying to understand why it did not respond to the changes you made??
Other than running a blue printed X 642 prop, my MG is stock with a pair of 2S 5000mAh 30C for power. With the winter coming, I hope to take the time to blue print the bottom of the hull. I have located an auto paint store that will match the paint for me, so I can touch up any body work that may be necessary to true up the bottom, and sharpen the edges. Not sure if that will make a big difference but, it is the right thing to do. One's bottom should be true, right?
Thanks for all the time you invested in your tests!
Boomer
