Well here it is everything is done i just have to mount the motor and so forth... I made slots in the motor mound so i can move the motor back a hair it worked out great!... One thing guy's don't do what i did when prepairing the prop shaft getting it scuffed up in the inside by using a drill and a small bit i had the prop on ( BAD IDEA) and was holding it with one hand while drilling in the prop shaft to scuff it up a bit and the bit got stuck and poof you guessed it the prop spun in my hand only 7 slice marks not to bad though but be carful not to do what i did take the prop off first before scuffing the inside hole up... it could have been worse..
I have a few ?'s about the flex units so here it goes
the teflon tubing you only push it inside the brass tube no glue?
you still grease the flex cable like on a normal boat drive right?
Also what's a good starting angle for the prop? straight with the bottom of the hull?
All and all i think it worked out ok THANKS everyone for all your help along the way!!
I bet this boat will be my smoothest one besides my SV27... May have to do more flex drive conversions!!
