Page 1 of 2 12 LastLast
Results 1 to 30 of 50
Thread: Project Red Evo
    Jun 2010
    90
    Default Project Red Evo
    I just received a Red Evo hydro from HK. I took it out for a test and I am impressed with how stable it is but not overly impressed with the speed. I would guess maybe 25 mph max. It came with a 32 mm 1.4 prop not the advertised 36mm 1.4.
    Any way I sold my surge flusher but happen to have a Turnigy Typhoon 500H Heli Motor 1800kv left over.
    So I am going to build the Red Evo with the outrunner and 6s lipo.
    should produce some decent speed.
    going to have to reinforce the hull and upgrade the shaft.
    will add some pictures soon.
    I do have one question though would a 120a esc be enough or should I go bigger ?
    May 2010
    OZ
    74
    6s on that size hull is stupid, 4s would be the maximum that you should run on that size hull.
    The motor you have would be ideal.
    FR
    2,096
    If you' ve got good batterie 3S 5000mAh first try other props and after upgrade the motor, TYPHOON or Leopard.
    I like this hull
    US
    5,557
    The 120a is MORE than enough..........a 90a would be fine. 4s is plenty as well............i would suggest a 380 28x58 or 28x68 in the 1900-2200kv range.
    Aug 2009
    tx
    3,534
    i agree 60 amp is ul1 power kicck azz in that hull it came with a 28 class motor right?
    US
    5,557
    Quote Originally Posted by Alexgar View Post
    It comes stock with a 28x48 2636kv motor..............
    This would be an upgrade in power on 4s: http://www.hobbycity.com/hobbyking/s...hless_Inrunner
    or a Feigao 380 12xl (28x67)at 2076kv...................
    Aug 2009
    tx
    3,534
    sounds good 6s sounds kinda heavy for a small hull
    Jun 2010
    90
    whats a Thread with out pictures.
    Typhoon for comparision
    Jun 2010
    90
    Pictures of the drive line
    Aug 2009
    tx
    3,534
    that a spacey hull
    Aug 2009
    tx
    3,534
    now that i see that go for the 6s with this
    http://www.hobbycity.com/hobbyking/s...mpeller_1350kv
    Jun 2010
    90
    So far I have installed a 90amp esc that I had left over from the surge crusher and reinforced the back of the boat where the rudder and strut mount as it was very thin.
    After taking it out for one run I noticed a hair line crack in the paint. Also there was a little more flex where the rudder mounts then i liked.
    so a few layers on thin fiberglass it stiffened right up.
    next I am going to try a few different props while waiting for drive line parts.
    Any suggestions on driveshaft and hanger ?
    I want to stick with 4mm as that is what is in my other boats.
    Aug 2009
    tx
    3,534
    Aug 2009
    tx
    3,534
    arent 4mm shaft hard to come by stateside?
    Aug 2009
    tx
    3,534
    sorry just realized the spec on your motor is what i suggested
    Jun 2010
    90
    great minds think alike
    Jun 2010
    90
    This is the stock battery location
    These show what I got for space.
    not lots but they fit. weight could definitely be an issue
    Aug 2009
    tx
    3,534
    maybe 2 3000 3s i bought some rhino 2150 3s and they are super light and 2 of them together are the same size as1 of my dualsky 2200s
    Oct 2008
    9,488
    I think running this on 4s would rip with the right prop!
    FR
    2,096
    Exclamation
    Yes I' m agree for 4S and 2200kV motor.
    This hydro is nice, hummm...
    Same size and design than the DF Vortex 22"
    Setup :
    2500kV BL motor 540L
    4S 1P 5000mAh LiPo pack
    X432 propeller
    Steven' s video :
    http://www.youtube.com/watch?v=oL6Bm2LKR7I
    Hope that will help you
    Jun 2010
    90
    Nice Video defiantly way faster than the stock setup on the Red Evo.
    I am going to try a larger prop on the stock set up today well see how it goes.
    I already have the 1800kv typhoon so I will start with that.
    Although reading the reviews on HK it seems that it measure's more like a 2000kv motor
    Jun 2010
    90
    I am starting to rethink the typhoon motor may be a little much for this boat.
    I just put one in my Apparition and wow this has a load of torque.
    going out for test runs tonight will try to get a video of it.
    4,204
    22" Hydro, may I add some suggestions:
    Ammo 2300 on 4s.
    Leopard 4050 on 4s. (ignor the photo kv rating)
    UL-1 power on 4s, which would be my #1 suggestion.
    SV on 4s or 5s
    - Diesel's Youtube
    - Diesel's Fleet
    Jun 2010
    90
    Thanks for the input I have only had boats for a couple months so I am still learning lots.
    I did some testing with the typhoon in my Apparition I think it may be a little much for the Evo. I tried to get a video if it but the camera man messed up and all I got is a 3 second clip of the boat coming to shore
    https://forums.offshoreelectrics.com/...908#post220908
    Ammo 2300 on 4s.
    SV on 4s or 5s
    Jul 2010
    fl
    656
    hi
    i run the red evo with the UL motor and it flys on 4s
    120 esc also
    Where did you get the Typhoon
    The boat can take more power.
    Best
    Ian
    4,204
    Quote Originally Posted by Graeme View Post
    I agree I think that motor maybe to much for this little hydro, to much torque. The ammo 2300 and a 36-40mm lifting prop may work well on this boat. First thing I would personnally do is search DF Vortex hulls on this site and find what people are running and then base my choice from that. This is just a vortex copy. If it's running the nightmare 4mm drive system ax that ASAP and run a Hughey JMO
    - Diesel's Youtube
    - Diesel's Fleet
    Oct 2008
    9,488
    What about 4s on the stock motor?
    Jul 2010
    fl
    656
    ok found it.
    cheap also.
    cool
    Oct 2008
    9,488
    Quote Originally Posted by Alfa Spirit View Post
    Setup :
    X432 propeller
    Steven' s video :
    That video is the mini.. 16"
    Jul 2010
    fl
    656
    it will run better on 4s but its only a 380 size.
    Stick a bigger motor in....lol
