Results 1 to 5 of 5
Thread: Ampba " ea outboard " question
    Aug 2008
    BH
    340
    Default Ampba " ea outboard " question
    Hi Guy's ,
    Currently i am building a 32 inch tunnel hulled boat , that has an Outboard powered leg , i have 2x 2s 40c batts & 120 amp ESC . just trying to ascertain what motor is used in the " EA- Outboard Class " , i have my eye on an Ammo 36-50-2300 or UL1 36-56-2030 ...
    Any advice appreciated ,
    Brad
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
    Oct 2007
    Br
    590
    Brad, EA allows any motor. However, you might want to check with your local club to see if they have any restrictions. What's the hull?
    Vi
    227
    Hey Brad,
    Most are going with the UL1 Motor, plenty good enough!
    Kris
    Aug 2008
    BH
    340
    Hi Guy's ,
    The hull is a Vantex that i have changed to outboard configuration , gave the guts of the original set up to my brother so he could put it into a project boat he sharing with his son . So i may buy the Ammo as it seems on specs it's a touch more powerful than the ul1 unit ( 60 amps ammo - 50 amps ul1 ?? ) , plus ammo has higher kv rating or would you still suggest the ul1 . The props i have are Octura x642 n x640
    Thanks Muchly ,
    Brad
    Aug 2008
    BH
    340
    Default pics
    Hi Guy's ,
    Attached a couple of pics of what state the project is at , just waiting for warmer months to finish painting ....
