These strong little 450 heli motors rip in my Villain with no trouble at all.
I'm wondering if they are worth a try in the EKOS?
http://www.hobbycity.com/hobbyking/s...trunner_1860KV
They are a 19mm bolt pattern and are setup for 60a ESC... 3mm- 130 couplers are available... I'm sure they would turn a 440 prop and are much more efficient than stock... rated a 500watts.
The stock motor mounts are water cooled... just might make an efficient little setup. Less weight, lower amps, lower RPM and bigger props... cheaper smaller lipos... and who knows... maybe more run time.
It's not like the KOS is a competitive hull anyway... Might just make it a fun one that is reliable.
