Wanted a neu 1521 1860kv or mega 22 45 1e or any other motors I might consider
I need one to run my 1/10 scale hydro on a 4 s setup thanks
I have a 22/35/1e 2600kv or a 22/45/2 1380kv. Both in excel condition. Had around 10 runs each.
Was looking for the 1860 kv 1521 neu
You may want to consider an ARC Motor
ARC ULTRA HIGH PERFORMACE 36mm Motors:
• Dimensions: 36mm x 65mm
36mm x 75mm
• Weight: 65mm - 305g / 75mm - 375g
• 25mm and 19mm apart mounting holes.
• 5mm shaft
• 4 poles
36-65-1 = (2080KV)
36-75-1 = (1680KV)
36-75-1.5 = (1130KV)
FEATURES:
- LARGER HIGH PERFORMANCE BEARINGS
- ENDCAP FEATURE RETAINING CLIPS TO PREVENT ENDCAP FAILURE FROM THE EXTREME FORCES THESE MOTORS GENERATE
The 36/65/1-2080kv motor may be the ticket on 4S! I've been running a 36/75/1 in my 6S powered Sport 40, Very Impressive power for the the size.
~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
****2008/9 MMEU LSO, 2008 LSH CHAMP****
~~~~~~~70 MPH Club Member!~~~~~~~~~
Which site can I get one of these motors from or full specs
Sorry forgot the link to the distributor.
http://www.lightflightrc.com/
Not in stock, need to preorder....
DJI Drone Advanced Pilot
Canada
