Results 1 to 3 of 3
Thread: Seaking 60A ESC timing setting
    Jun 2008
    ON
    896
    Default Seaking 60A ESC timing setting
    So from the factory, the setting is at 15 degrees timing.
    The motor in the shockwave is a 36-50-04 (4 turn, 3300kv).
    Should I be running the timing that high? From what I have read on here and other online sources, higher timing means higher speed, but also higher temps. Should I program it to start at 0 timing, and monitor and go up from there? Or is it safe to start higher/leave it at 15?
    Aug 2009
    tx
    3,534
    let me dig up my manual
    Sep 2009
    TN
    1,598
    I would say 15 should be fine. Probably gonna be your best balance between speed vs. heat.
