So from the factory, the setting is at 15 degrees timing.
The motor in the shockwave is a 36-50-04 (4 turn, 3300kv).
Should I be running the timing that high? From what I have read on here and other online sources, higher timing means higher speed, but also higher temps. Should I program it to start at 0 timing, and monitor and go up from there? Or is it safe to start higher/leave it at 15?
