Results 1 to 11 of 11
Thread: problem with my scratch build 36 inch
    Aug 2010
    fl
    91
    Default problem with my scratch build 36 inch
    ok so i have put all the layers of wood but now on the bottom i have noticed that right side lays flat and leftdoesn`t so any help or suggestions appreciated>
    Feb 2010
    St
    788
    Alrite bud have you skinned the top of the hull ? any pics
    Aug 2010
    fl
    91
    Quote Originally Posted by F1 madness View Post
    no i have not
    Feb 2010
    St
    788
    as you skin the top place some bricks on the top once youve lined it up.
    that might help,looks like its slight warped,also you need to sort out the bottom of the rear part of the sponson
    Aug 2010
    fl
    91
    you think if i add bondo to the warped side it ll make it even?
    Feb 2010
    St
    788
    no wont work,better to try and straighten it the way i said,iv built alot of boats and if i have any warping i cure the way i said
    Aug 2010
    fl
    91
    it`s a lot shorter not a little
    Feb 2010
    St
    788
    itll work im sure of it,if you bondo it out you may have handling problems
    Aug 2010
    fl
    91
    what side do i place the brick on
    Aug 2010
    fl
    91
    Does it take shape if i leave it over night or ?
    Feb 2010
    St
    788
    Quote Originally Posted by 08gtrking View Post
    Once youve glued the top skins on,place the bricks across ways,1 @ the back and 1 roughly central of the hull and leave over night to cure,that should hold it from then on and you can carry on with the rest of the build
