Need a good 60 amp esc thats easy to program,any suggestions.
Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
http://www.hobbypartz.com/07e-c-seaking-60a.html
I ues this one and love it.Alos ships from the usa.
These are the same esc, Hobbywing is the maker, also the one from hobbypartz is a version 1 & the one from HK is a version 2 (you can tell by the cooling in/out). HK re-badges their crap, they actually make nothing they just distribute. This is a better esc over the aquastars (IMHO). I run a aquastar 120 and a hobbywing 120 & 180 I think the hobbywings run better. Jan at kintec racing has these and arrives in normally 3 days. I would just spring now for the 90 or 120. Shot him a email kintecracing@msn.com and make sure he has them in stock cool dude to deal with. If you go the aquastar route order the 120 from here at OSE, they are called swordfish made by hifei. Their the aquastar esc's (rememeber HK makes nothing) and steve will normally warrenty it if something should happen as long as you don't blow the thing up(which is more then HK will do). The are good esc's just don't have the burst rating like the hobbywings do. They are without a doubt worth their price of $75. With either esc you go with get a programming card, makes your life easier.
Got 120 amp seaking no program card,still works really well.Running 3s 5000mah turnigy bat, the 120 esc,pro boat stainless prop on the shockwave brushless .On the stock steerable system pretty mucha waste of time..ha
