Results 1 to 8 of 8
Thread: Turnigy 120A ESC question....
    Jan 2010
    335
    Default Turnigy 120A ESC question....
    I just put one of the Turnigy 120A escs in my UL-1. Everything is stock except the ESC.
    http://www.hobbycity.com/hobbyking/s...hless_Boat_ESC
    I was running it a few times this weekend and it seemed to cut out prematurely. At first I thought it was my packs, but I tried 3 different sets and they all seemed to run a few laps and then it would die out to just enough throttle to bring it back in. Every time I pulled it in it was cool as a cucumber. Could there be something wrong with the programming that handles cut off?
    Aug 2009
    422
    Hi I had that problem where it would just cut off randomly so i disabled the bec and rana seperate rx back and now have no problems and that was running on 2s packs.
    hope that helps.
    :canada
    Jan 2010
    335
    Quote Originally Posted by ezhitz View Post
    hope that helps.
    Now was your problem it completely cutting out as in no throttle at all?
    Because for me its like its going into that limited throttle mode that a lot of ESC's have for low voltage....
    Nov 2007
    6,927
    disable the LVC and watch your time! See if that works.
    Mini Cat Racing USA
    www.minicatracingusa.com
    May 2008
    1,744
    Quote Originally Posted by mschaffer66 View Post
    I had the same thing with the same boat and same esc. It would just thottle down as though the LVC had kicked off, but the batteries had plenty left in them. I just turned off the LVC.
    Jan 2010
    335
    LVC disabled....time to try it out.
    Apr 2009
    BJ
    251
    Program your ESC LVC to 3.2 or 3.0V/cell and soft cut(limited power) instead of hard cut(stop responding) . I ran this setup for two years and that's perfect.
    BTW, higher voltage recommended for the ESC will have to handle MUCH LESS current, which makes it work more comfortably. The Seaking/Marine-120A has switching type BEC inside, don't waste it! I ran 6S on my mono even it's just 58cm in length.
    Feb 2010
    12
    My marine 120A esc cut off completly also. That problem was the BEC cutting out on me.
    I have a UBEC now and it works like a charm.
    It does like some extra caps when you really turn on the amps
    With some extra caps it seems indistructible for now.
    I have my LVC set at 3.2V and that seems to work fine with the 4s 40C 5000mA Lipo's I use.
    Marcel
