Results 1 to 10 of 10
Thread: Motor cleaning question ?
    Jul 2010
    AR
    88
    Default Motor cleaning question ?
    Manual says to clean out the motor after a day of running with a water displacment---WD 40 or Corrosion X and then re-oil bearings. I have both and bearing oil. The Seaplane guys swear by Corrosion X for radios and speed controls but NOT brushless motors. In fact some warn do NOT use in your motor. Whats everyone thoughts on this. Thanks for the help.
    Stringfly <>+++++
    Apr 2010
    Uk
    487
    I never did any maintanence to the motor in my supervee its been in 3 different hulls been sank twice over propped and is still going like new !!
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    Jul 2010
    AR
    88
    Thanks for the input.
    Stringfly <>++++
    WA
    2,038
    Quote Originally Posted by stringfly View Post
    Stringfly <>+++++
    Maybe they are confused and thinking back quite some years ago when corrosion x was not good for electronics. In fact if you have corrosion x that has a 2004 or earlier date I would not use it for anything electronic. It was known to delaminate the PCB boards of your esc, rx and servos. It might have been fine for some items but it was not initialy designed for electronic circuit boards. Thats not the case today. Many RC enthusiasts enjoy using it on just about anything in our hobby.
    John
    Change is the one Constant
    Jul 2010
    AR
    88
    Thank you John.
    May 2010
    693
    All the guys in our club use it.
    Jul 2010
    AR
    88
    Default Corrosion X
    I do have a new can (red) of Corrosion X. Osprey21, They do spray it in their motors ?
    Stringfly <>++++
    May 2010
    693
    Yep
    FR
    2,096
    Nothing to do,
    ONLY fine oil in ball bearings, sewing machine oil is perfect
    Jul 2010
    AR
    88
    Than ks guys.
    Stringfly
