after my friend drove mine he wanted his converted so I thought id share with you guys how I done it. Way better than the stock setup.
damnnn....
Here are a few pics with linkage all connected, right rudder pickup cools esc and exits out right side of the boat and the left rudder pickup cools the motor and exits out the left side.
Did you notice any decrease in top speed due to drag? Looks like the rudder setup on the shockwave 55.
40mph is perfect for the fastech. Fast enough to be exciting, slow enough to not overheat and long run-times. Gotta love the extra insurance of dual cooling. Nice job Deserthobbies!
The dual cooling actually works great, it shoots out a pretty good stream of water only having to go through one component. ran it last night in my pond which is 1/4 mile long by 300 feet wide, water temp is 90 degrees and the motor and esc still stayed cool, just stocked the pond with 15,000 baby catfish and the rudder must have hit one no damage to the boat but the rudders cut the 6 inch channel cat in 3 peices LOL.
I also have dual rudder set up its way better than stock I have linkage connecting the rudders together instead of having them both connected to the servo.
Hi deserthobbies!
very nice job for your fastech!! if that would give the Fastech if i left the turn fins off in stock statut?
yes I think I already lose in stability than with the original engine at full speed with a propeller X642 boat swaying from right to left! by the way, how to fix this problem?
