When you say "slow to start", are you using the stock prop and is the boat cavitating (or ventilating) the prop a lot??
The stock plastic prop does that. You can help it out a bit by cleaning it up with some light sanding, but you'll really want to get a nice Grim 42x55 or X440/3 on there.
Another thing that REALLY helps the SV27 is to block sand the back portion of the hull. At a minimum, scuff the bottom paint with some 320 or 400-grit wet-dry paper. If you can get the bottom VERY flat and the trailing edges VERY sharp, it'll be faster.
However, just getting a good prop on there would be the place to start.
Darin E. Jordan - Renton, WA
