Results 1 to 7 of 7
Thread: connectors pk 4mm
    Mar 2010
    38
    172
    Arrow connectors pk 4mm
    hi guys,
    what do you think about pk 4mm for esc 180A turnigy and two lipo 3s 20-30c in serie or single lipo 6s?
    2,686
    5mm bullits minimum. I use 6.5's between the motor and esc. what motor??
    Mar 2010
    38
    172
    i use the proboat A3630-1500 of course for the 4s the pk 4mm are good??
    2,686
    Quote Originally Posted by xxxrems38xxx View Post
    You're probably ok on the proboat motor. If you were running a larger castle/neu I would use 5mm+ for sure.
    Mar 2010
    38
    172
    and the deans are best compared pk 4mm?
    2,686
    Deans are ok for low amp setups. I quit using them a while back. They are more difficult to solder than bullets. I would use 4mm bullets over deans.
    9,398
    These are really nice and far better than the bannana style 4mm. Just in case you pull more amps, these will take it and are lower in resistance than bannana 4mm types.
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    I hate run of the mill bannana 4mm connectors, crap.
