Results 1 to 10 of 10
Thread: BJ battery pack hold downs
    Oct 2007
    26
    Default BJ battery pack hold downs
    What are you guys using to hold the packs in the trays?
    Oct 2007
    26
    I just saw the pics, velcro it is.
    Im going to use some strips instead of a whole slab down the tray though
    :shrug:
    Jun 2007
    LA
    764
    I got the slabs cheap, so it's not a big deal for me. I kinda over did it on purpose. Normal velcro strips work fine.
    Actually, I am going to remove the battery trays in mine so I am put my one set of lipos in that don't fit now!!!!!
    Nj
    4,735
    From what I have learned it's better to keep the weight as low as possible. So having the packs down all the way should help with handeling.
    Oct 2007
    26
    On turns it seems a bit top heavy, I may remove the trays at a later date also
    Oct 2007
    GA
    27
    Removed the battery trays......err, I mean ripped them out! They come out pretty easily if you pull up on the tray where it is glues to the side of the hull. The cement looks strong but it's brittle. It freed up alot of room and the batteries ALMOST fit flat on the bottom but not quite. A large flat piece of velcro seems a good way to keep them secured.
    Nj
    4,735
    Much better thats what I would have done before even running it.
    Oct 2007
    26
    Just wondering what those contributed in the structural support for the middle build?
    Jun 2007
    LA
    764
    Naaaaaaaaaaaaa it's fine without them....
    Quote Originally Posted by Spoolin View Post
    Aug 2007
    Paradise, Hawaii
    247
    on my nitro, converted to FE, I also took the servo tray out of the box, removed the box and remounted the servo tray, put my RX in a balloon, Im using the sv set-up, ESC is waterproof, stop the leaks and tape up good, no problems.
    it made a hell of alot of room for 6000 to 8000 lipos.
    Island Boys Fast Electric Hawaii
