Results 1 to 11 of 11
Thread: Throttle/ESC problem
    May 2010
    693
    Question Throttle/ESC problem
    Once I connect the battery packs and squeeze and hold the throttle trigger to arm the ESC (1 beep) then release the throttle trigger (3 beeps) the motor starts to run. It's not turning very fast but I can't seem get the throttle to close all the way. Adjusting the trim knob only brings it down somewhat.
    However it will stop running if I push the trigger all the way forward and hold it there.
    WTF?
    On
    7,279
    Try reversing the throttle, mines set to "R".
    May 2010
    693
    Mine is set on R as well - will try the N position.
    Well.. it was even worse in the N position.
    Dec 2009
    2,553
    It sounds like the esc is not recognising the neutal position of the radio as the off position.
    I'm guessing this is a SV27 motor & esc with a Tactic 2.4? Some radios require the throttle to be set in the reverse position and the Tactics come through that way. (Futaba requires reversing for use with an esc as well)
    With a Turnigy esc you are supposed to (on it's 1st use or when moved to a different radio) hold the throttle wide open when applying battery power, then after it beeps release the trigger back to it's neutral spot. This allows it to set it's throttle limits. Don't know if it will help with what you have (it may put the esc in programming mode so if you have a manual check it) but it's a thought.
    May 2010
    693
    Quote Originally Posted by bill34207 View Post
    It sounds like the esc is not recognizing the neutral position of the radio as the off position.
    Yes sir.
    Dec 2009
    2,553
    I'm really at a loss for an explanation on it myself. It's not the same as the esc that came in my UL-1 (which armed and worked like it's supposed to right out of the box).
    If it's a new boat you might want to take it back where you bought it. There may be something "not right" with the esc or radio. Otherwise you might check with Hippie or Hebner. I think both of them have SV27's
    May 2010
    693
    Well I just tried it again and everything worked as it's supposed to.
    I think I had the throttle trim set incorrectly.
    danged newbie
    On
    7,279
    Duhhhhhh,,,,we've all been there at one time or another. Glad its working.
    Dec 2009
    2,553
    Quote Originally Posted by osprey21 View Post
    danged newbie
    Doh!
    May 2010
    693
    Whelp... I'm heading out to test-run the boat - wish me luck.
    Oct 2009
    NC
    483
