Here is my new boat http://www.youtube.com/watch?v=nIEUwuNdeoQ
Hull is Delta force 33 cyberstorm
motor: neu/castle 1520 1y
esc: turnigy marine 180A
battery: 6S lipo
battery: 6S lipo
How long have u been running the Turnigy ESC with 6s?
thanks in advance
There is a very thin line between Hobby and Mental Illness...
OK just be careful...
I dont want to scary u,but i think that this speed control will not survive the continious use of 6s bat...
Are you using your ESC bec or external bec with this ESC?
DJI Drone Pilot
Canada
Using (Seaking (turnigy) 180 with NEU 1527/1Y on 6S with X447/3 prop. No problem at all.
External receiver battery. Can't use BEC with 6S.
I also run a 1515/1Y in my DF33 with X447/3 prop, CC 240LV, 4S, separate battery pack.
Mini Cat Racing USA
www.minicatracingusa.com
My set up is the same hull. 1521 1Y, 6s 5000 turnigy, 180 turnigy esc using the bec, and a 3/447. This set does the mile course and milling lap no trouble. The speeds are very quick, a lot quicker than yours. I think you can go a lot biiger in prop yet. I have not read that you cant use the bec on 6s???????? I have ran this set up about 30 times with no trouble at all.
The manufacturer and instructions do not state that you cannot run it with BEC up to 6S, however I dont know of any ESC that has the BEC function and allows you to run it to full cell capacity while using the BEC capability. But I do know of at least 4 manufacturers that warn you NOT TO run the BEC above 3S or 12 cells nimh. These would be Schulze, Castle Creations, MGM and Jeti. Theres probably more but when it comes to the switching BEC function on an ESC the recommendations are pretty clear.
Take it with a grain of salt if you want. There have been enough users of the Seaking and Turnigy owners who smoked their BEC function on their ESC. Did they do it on 5S or 6S? I have not tracked them. I just know from experience that on any ESC I use it gets a UBEC or a battery pack on any setup over 4S.
John
Change is the one Constant
looks decent with the S215 on it
I have used most of the controllers listed on 6s with the bec working. The simply method of cutting the red wire from the esc doesnt turn the bec off, it just stops power getting to the reciever. Unless there is a switch or programing to turn it off, it just runs all the time regardless. I am no expert, but dont see what difference it makes how many volts are supplied to the esc, the bec still has output at the regulated voltage. The techs at Castle comfirmed this in an email. If anyone can shine any lite on this, please try.The manufacturer and instructions do not state that you cannot run it with BEC up to 6S, however I dont know of any ESC that has the BEC function and allows you to run it to full cell capacity while using the BEC capability. But I do know of at least 4 manufacturers that warn you NOT TO run the BEC above 3S or 12 cells nimh. These would be Schulze, Castle Creations, MGM and Jeti. Theres probably more but when it comes to the switching BEC function on an ESC the recommendations are pretty clear.
this boat is now painted https://forums.offshoreelectrics.com/...ad.php?t=14871
the esc bec broke but the esc still works with external bec.
