Results 1 to 4 of 4
Thread: Grimracer and Octura
    Mar 2010
    38
    172
    Default Grimracer and Octura
    hi guys!
    between grimracer and octura what products are best or are they equivalent?
    WA
    8,335
    There is not "best" when it comes to props... It's all going to depend on your specific setup and needs.
    I will give Grim the nod, however, on out of the package quality. His props are made of some very tough material, and come closer to RTR than Octuras. BOTH make good performing props, but again, it'll depend on your needs as to which will work best for you.
    Darin E. Jordan - Renton, WA
    May 2009
    535
    Octura also has a much larger selection of prop choices as does ABC...but I find that the Aquacraft/Grimracer work better (so far) on my VS-1 tunnel.
    2,731
    I havent run grim props so i cant comment on effectiveness but since I saw grim saying that they are ABCs I wouldn't contemplate running one either, I would rather buy an ABC and give the designer/MFG all my money than buy the same thing from a reseller that takes their cut before passing the money on, that way the designer can spend more on R&D and you get a bigger range of better props in the long run.
