I dont take pre-orders. Reason being its not possible to gauge how many we will really get in our hands. If i take 10 pre-orders and only 5 come in. Thats 5 pissed off customers.
Steven Vaccaro
I am already thinking a pretty little green 2200 would fit in there quite nicely.
Did you notice that they say "No Tape Required". Should be interesting to see how that works.
I was on board for Venom P1 till I got a real close look at the website and did some reading, To hell w/the P1 I want a Titan now.
The features and inovation + the TRX warrantee has me sold !
The problem will be if either make it to market before the winter.
Steven Vaccaro
very very nice......traxxas is truly an innovator
I love how they layed out the interior..talk about clean
I just picked up some sweet 5000mah 5s packs that could make this thing move
I would assume that Aeromarine did not have the copyright to the Titan name for a boat hull....
Looks good tho!
Don't bother with a hobby store..
Steven here at OSE has the goods!
http://www.offshoreelectrics.com/pro...series&cat=134
I'd go with the 1520. Bigger props, and 6s still.
The 1717 would sink it, It's a big bastard.
The boat is also a big bastard. It's 36" remember. The 1717 would actually be good for a mono this size. It looks pretty dang good stock though!
I have a 1717 in a Losi XXL Monster truck running on 6s, The truck is roughly 16+lbs and that motor yanks it around like it's a matchbox car.
I bet it would be a great motor for it, tons of torque !
im guessn its probally just about the wieght of a 30" mono due to abs; so im guessn that motor is pretty good
Yes it does look good, and let's face it... If u upgrade the motor much a bigger esc will be in order which kind of ruins the clean looks ofthe well thought out electronics tray.... I'm gonna keep mine stock for awhile.... I still remember the first time I whipped out my erevo at a house party on 6s!! Everyone was impressed to say the least.... Traxxas knows how to create attention, and this doesn't look like it's going to dissapoint! :)
I understand where you guys are coming from but wouldn't the 1518 be much more efficent even tho it's a slightly higher KV than the TRX motor ?
TRX doesn't make junk but the Castle Motors have to be built with higher tolerences and be more efficent than them ? They are a Steve NEU design after all.
Hull Type Deep-V
Dead Rise Angle 26 Degrees
Hull Length 36.5 Inches (927mm)
Overall length 40.8 (1037mm)
Beam 9.5 Inches (243mm)
Weight 72oz (2041g) = 4.5lbs
Speed Control Type Traxxas Velineon VXL-6s, Watercooled
Input Voltage 7-18 NiMH Cells, 2-6 LiPo Cells
(8.4-22.2 Volts DC)
BEC Voltage 6.0 VDC
BEC Current 3A
Power Wire 12 gauge Maxx Cable
Thermal Protection Thermal shutdown
Low Voltage Detection Yes (user enabled)
Motor (electric) Traxxas Velineon® 540XL Brushless, watercooled
Drive System Direct Drive, 0.150” Flex Cable
Outdrive Adjustable Aluminum
Prop 2-blade composite, 42x59mm
Transmitter TQ 2.4GHz High Output with Traxxas Link™
Receiver 2218 2.4GHz Micro 5-channel
with Traxxas Link™
Servo 2056 High-torque waterproof
Batteries (2) Power Cell 7-cell
with High Current Connector
Charger Not included
Skill Level 2
Yeah, It's a great motor, BUT it isnt a 6s motor. 5s may on that 1518. I had one, it's a great motor. Reguardlees of weight, once it has 6s in it, and being that it IS a big boat, it's still a lot to push. Notice only a 42 mm prop comes on the boat. Any bigger and the esc goes poof and the motor overheats.
