Results 1 to 15 of 15
Thread: Receiver Pack Voltage??
    WA
    8,335
    Default Receiver Pack Voltage??
    Hey Guys... I have been running some small (150mah) 4-cell Rx packs in my little riggers and my N1-Mono, and have had no issues...
    On my new P-Mono that I'm getting together, I was thinking of using something more substantial, since I'll be dealing with a much bigger servo, etc...
    I was wondering if I would damage anything by using a 6-cell Rx pack??? I have some 2/3A 6-cell packs that are otherwise just sitting here and are brand new that I was thinking of using...
    Otherwise, I'll remove a cell from them and just use them as a 5-cell Rx pack... but if I could avoid having to do that, I'd like to...
    If you have any experience with this, please chime in...
    Thanks,
    Darin E. Jordan - Renton, WA
    IA
    811
    What Rx are you using. I know the Spektrum receivers can handle all the way up to 9.6V. If the Rx can handle more than 6V it may regulate it down to 6V.
    WA
    8,335
    Quote Originally Posted by NorthernBoater View Post
    Good Point... I forgot that piece of info...
    I'm using mostly Hitec DCX dual conversion 3-channel Rxs... I do have a couple of JR RS-310 Rxs, but I've had glitching trouble with them so I usually don't use them for hot race setups...
    I'll go look at the Rx specs and see what it says... I'll do the same for the ESC...
    IA
    811
    I found this site that has some info. Stick with the 5 cell pack.
    http://www.robotstore.com/store/prod...849&catid=1546
    on
    1,921
    i have so much trouble with my rs310's URG.
    i run 4 cells on my jr's and it seems to get worse then with out a receiver pack.
    EYEKANDYGRAPHICS
    www.rclipos.com
    Cool
    Frankly, running anything less than 6 volts to the receiver makes little sense with today's big fast models. I run 5 x 350mAh cells on my LSH boats and 5 x IB1200 cells on everything else. Virtually all current receivers will handle 6 volts very well. I used to run a 9v alkaline battery and it worked fine on small boats with small servos.
    An additional tip - plug the receiver pack into the 3rd channel slot on the receiver - not the BATT slot. The 3rd channel is on a buss that will allow full power to the servo rather than heavily regulated = faster transit time and more torque.
    Nj
    4,735
    Fluid will this work with BEC units also? My BEC units are rated up to 50 volts & 5 amps.
    Ga
    5,267
    Quote Originally Posted by Eyekandyboats View Post
    Man if I had all the JR problems you do I would have thrown that junk out the window a long time ago.
    Between Casey and I we own eight JR TXs from XR3s to XS3s not including three air units. I can't tell you how many JR RXs we have. In over ten years we haven't had a single problem with any of them.
    Perhaps you just got a bad one or your problem stems from something else.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Jul 2007
    up
    233
    Default rx pack voltage!
    I use 9 volt battery for rx power and some models above 6 volts jump around because of too much voltage. Now you take micro, 6 volts is it and i use good micro servos as they don't strip gears. Now JR. servos work great and no problems but as i read things same equipment is always best and scrimping on $ signs cost in the long run!
    Oct 2007
    NS
    26
    I use 7.4 lipo rx packs in my boats and LST monster truck.
    I use voltage regulators,of which most allow you to select 5 or 6 volt output.
    Cool
    Again guys, modern receivers already have a voltage regulator in them. Save your money - unless you want to use 4S or 6S receiver packs.
    on
    1,921
    wahoo.
    I ran the receiver pack in through the 3rd channel and i can say i have zero problems now.
    EYEKANDYGRAPHICS
    www.rclipos.com
    WA
    8,335
    Thanks Jay... very useful information...
    Just to clarify... is there an issue then with running 6-cells to the RX as opposed to 5-cells?? Can the built-in regulator handle the extra 1.2V?? My application is NOT going to be hurt by the extra weight...
    Darin, it depends on the receiver. The specifications for each may be different, I know that older Futabas listed up to 8.4 volts input voltage - I used a 9 volt alkaline cells with good success. Current Futabas may be different....check your manual to be certain.
    Jun 2007
    5,190
    Thanks, Darin and Fluid[ AKA as the GURU] for this info.
    Douggie
