Results 1 to 18 of 18
Thread: 45.6 mph sv27
    Apr 2010
    Uk
    487
    Talking 45.6 mph sv27
    Hi guys took my Supervee out today and got her up to 45.6 mph the boat was running beautifauly nice and smooth.
    Setup:
    Grimracer 40x52 3
    Ammo 2300
    UL-1 ESC
    2X Team Orion 2400 rocket packs
    Neutral tabs
    Positive out drive
    Rudder tucked under.
    GPS used was a Garmin forrunner 101
    Apr 2010
    Uk
    487
    Is that a good speed ??
    4,204
    Quote Originally Posted by Brushless01 View Post
    Slightly change your set-up to a grim 42x55 prop and grab some 2s 5000mah 40c lipo's and you should be in the low 50s
    - Diesel's Youtube
    - Diesel's Fleet
    Apr 2010
    Uk
    487
    Hi Diesel I also have some 35c 6400's but it bounces around like mad with them. I probably wont change the prop as its fast enough how it is. And cause ose dont have any 42x55's SAB in stock
    4,204
    Good luck with your re-build. If you really want that prop Chuck here on the forum can s&b one for you. He does great work.
    The bouncing maybe a CG issue with those bigger batts. Move them forward, to do this remove the battery trays.
    - Diesel's Youtube
    - Diesel's Fleet
    2,686
    Thats flying for an sv! You really gotta dial in the handling of the sv to get that kinda speed!
    4,204
    If he had a different motor other than that 2300 he could run that 42x55 with slight negative on the trim tabs and run 47-48 and very stable (see my video), but that ammo motor likes the boat to run neutral or loose, to wet with that motor and temps get hot quick. Like I said with the 42x55 and the ammo 2300 you can break 50 without a doubt (just ask wizard)
    - Diesel's Youtube
    - Diesel's Fleet
    Apr 2010
    Uk
    487
    I already removed the battery trays that was the first mod i did thanks for the recommendations Diesel.
    2,686
    I never did like the ammo 2300 in my sv. I think the ul-1 motor would have been a better choice.
    483
    Wink 52.7 mph
    Like Diesel said I got mine up to 52.7 mph with an Ammo 2300 and a 42/55 Grim prop
    But I liked it better with a X442 If I ran it for a whole charge the temps were lower
    and it didn't flip as easy
    Apr 2010
    Uk
    487
    Thanks wow wizard that thing flys i gotta got a 42x55 next !!!
    483
    Cool just watch your temps that was a 2min run more than that and things can get hot Impotent upgrades are 5.5mm connectors at battery and 4mm connectors at motor
    Apr 2010
    Uk
    487
    What was hot motor or esc i have the transom and rudder pick up will it still get to hot ??
    4,204
    - Diesel's Youtube
    - Diesel's Fleet
    4,204
    I average 100-110 degrees F on my setup after a 3-4 minute run. Keep everything under 130F (playing it safe). I think around 150F - 160F the motors will de-mag, not sure though I did have my traxxas velineon motor up to 180F before by accident and it still runs like a champ.
    - Diesel's Youtube
    - Diesel's Fleet
    Apr 2010
    Uk
    487
    Thanks Diesel !! wow 180 thats scorching hot so about 140f on the sv should be fine? I wont be running it for a while as its being reinforced with carbon fibre on the transom and cloth everywhere else then im gonna make carbon stringers
    4,204
    Thats getting up their, try bringing your run time down by a minute or so. Are you using the stock water jacket or a upgraded one?
    - Diesel's Youtube
    - Diesel's Fleet
    Apr 2010
    Uk
    487
    Ose water jacket havent tested temps yet tho
