Newton has the plans for the Smokin Joes. I work with Autocad for work, and when I have free time available, I will fiddle with hydro plans. I take the newton plans, fix all the discrepancy's that hand drawing things causes, and then I have them on Cad so I can scale up, scale down, make changes, etc. We have a huge scanner as well that converts the paper plans to a .pdf file that I can drop into Autocad, from there is where I do the initial trace in. Then I can send my Autocad file to the laser cutter to get them cut out. He even supplys all the wood that I use (1/16th inch 3 ply, 1/8th inch 5 ply). I have the Newton Circus plans, and plan to finish scanning them in, and correcting all the little errors, but it will be another month or so before that is done as I am in no hurry since I have to build the '82 Executone boat, along with 2 others from the same framing plans. Here is what the boat will look like finished:
