Results 1 to 3 of 3
Thread: Swordfish Frustration
    Sep 2007
    NJ
    1,253
    Default Swordfish Frustration
    Well I'm taking a break from these freaking things. I finally got one them to run. But not the other one !
    Trying to set up a twin drive outboard MM. Took the y adapter out of the equation and hooked up just one to 4s and it ran --- set the other one up the same and nothing! WTF????
    I'm going to give it one more go tomorrow evening and if I can't get it -- I'm selling these things and using Etti 150's!
    Hey I wonder if these swordfish 120's will cook up on the grill?
    We did it with a Bang!
    Cats Are Where It's At!
    Apr 2010
    3,480
    If using two with BEC, the red wire must be removed on the receiver connection on one of the ESC sides of the Y connector.
    ( you may already have done this)
    Sometimes I can get them both to calibrate at the same time, other wise, I calibrate one side at a time, using the BEC connected side of the Y connector.
    I've found that the 70/30 w/throttle trim full helps with calibration.
    Good Luck, hope this helps.
    ________
    LANSING DELTA TOWNSHIP ASSEMBLY
    Sep 2009
    HI
    1,679
    I have calibrated both of them together and run both of them with the BEC. They run cooler than CC hydras in my twin cat.
