Results 1 to 1 of 1
Thread: New toys and battery issue
    Jun 2008
    OH
    2,345
    Default New toys and battery issue
    I ended up ordering one the small chinese hydro's.
    In the feedback someone said the 3S 2200 battery would fit... Ya right.
    The next issue is with the push rod. The assembler wallowed out the hole in the servo arm and its loose (I dont like loose). The other issue seems to be they put the rubber boot to low. Its on a bind and the rudder isnt even hooked up... So Im going to re-bend that.
    My last issue is the antenna thingy... Im going to run a 2.4 GHz system. It appears they want me to cut my antenna and do some solder work into their system? Should I?
    Im a bit unhappy about the batteries. The 2200 battery is WAY to big. The 1000 mah 15C 3S looks about right. The 1300mah 20C 2S I have looks like a good fit also.
    So a little work tomorrow and hopefully a run on the 1000 15C 3S packs...? Or should I try the 2S?
    Please help.
    Side note: Guess I will use the 2200 mah packs for my 25" Prince boat...
    Small hydro next to my Micro Patriot...
