Page 3 of 12 FirstFirst 12345 ... LastLast
Results 61 to 90 of 338
Thread: Project Genesis!
  1. #61
    US
    5,557
    I would hope that the motor could run at 35k rpms which is what it would turn unloaded on 8s. Comments on the motor on hobby king has people running it on 10-12s in planes. However, i'm not buying into it running over 40k.......its just not a high quality motor.... sort of mid-grade. Make sure you prop it on the low side and use a full water jacket......the long one.
    http://www.offshoreelectrics.com/pro...ose-mjacket-XL
  2. #62
    Apr 2010
    3,480
    Ah, so volt rating is in part based on Kv (max RPM).
    This could be a good cheapie to experiment with and most likely blow up at some point. Doesn't say max watts, so we'll see just how many watts can be squeezed out of it!
    I'm guessing using a short water jacket on an XL motor would allow some parts of the windings to overheat while other parts stay within operating range?
    ________
    Herbal Vaporizers
  3. #63
    US
    5,557
    Quote Originally Posted by FighterCat57 View Post
    Somewhat i guess................ If it was a 5000kv motor it wouldnt have a 6s rating, whereas a 1500 most likely would.
    Probably in the 1000 watt range.
  4. #64
    Apr 2010
    3,480
    1k watts doesn't seem worth while or worth the extra $ for the setup. Was a fun idea though!
    Back to the 1521/1.5d setup; I'm thinking that this would make a great setup for the Genesis:
    6s2p 60c 10k, T180a, m445/447, possibly x452
    ________
    DC MEDICAL MARIJUANA DISPENSARY
  5. #65
    Jul 2009
    5,669
    I think your esc is only going to handle the 445. And Id imagine even at that, your esc is going to be about at its max in every way possible. Im not saying dont try it, but Id ease into it (prop wise) and see what happens..
  6. #66
    Apr 2010
    3,480
    Quote Originally Posted by tiqueman View Post
    I think your esc is only going to handle the 445. And Id imagine even at that, your esc is going to be about at its max in every way possible. Im not saying dont try it, but Id ease into it )prop wise) and see what happens..
    Hmm. That was the Castle recommended starting prop. Perhaps I'll start with a 40, 42 then see how it goes from there... Thanks!
    ________
    Og Kush Pictures
  7. #67
    Jul 2009
    5,669
    On the motor though right? The motor will have no problems swinging a 445 at all.... but your esc may not like it, and certainly wont like anything bigger. You will be pulling more than 180A.
  8. #68
    Apr 2010
    3,480
    Ah! Got it. I'm guessing the Hydra 180 has a much higher capacity than the Turnigy 180.
    I have a Castle MMM that I'm not using. It's a killer car ESC. I wonder if I could adapt it to the boat?
    Some conformal coating and a water cooled heat sink? (warranty void I know)
    ________
    WASHINGTON MEDICAL MARIJUANA
  9. #69
    US
    5,557
    The 1521 1.5d would make it really move out nicely on 6s..............i too would watch the props and personally would never even consider a 452................
    Be careful with the Castle..........its only good for about 120a
  10. #70
    Aug 2008
    By
    159
    Hello
    i recived yesterday my Genisis.
    First i want to test it with the original Hardware before i build it with two motors.
    So here my Question
    Has anyone a programming manuel for the original esc.
    Maybe someone can help me
    thanks from germany
    mudl
  11. #71
    FR
    2,096
    @ FighterCat57 : 10S is too much, 6S is good with a 1500kV motor like Feigao 580L 8 turns or 9 turns, if you want to run 8S you will need an expensive HV esc.
    May be a twin setup is cheaper, 5S per 540XL/9 motor and 2 Turnigy 120A esc. The problem with twin are stingers they must be long enough, more than 10cm
  12. #72
    Apr 2010
    3,480
    See Alfa's post.
    ________
    CHEVROLET KODIAK SPECIFICATIONS
  13. #73
    Apr 2010
    3,480
    The MMM? Yeah, I only see it at about 130-140 peak on the tell tale, haven't looked at the specs on it and don't know the constant.
    The next question is drives. The 1521 is an 8mm shaft. The current drive is 4mm. Which might not be strong enough for the power of the 1521.
    I'm beginning to think that a wire drive might work better. (Jeff, this is your queue)
    Any suggestions?
    ________
    EXTREME Q VAPORIZER
  14. #74
    FR
    2,096
    Quote Originally Posted by mudl View Post
    Hello
    So here my Question
    thanks from germany
    mudl
    Here is it
    Attached Files Attached Files
  15. #75
    Aug 2008
    By
    159
    Hello
    Thanks for the manual
    For building the cat with two Motors i think also about drving 8s Lipos.
    Maybe i put in two scorpion Motors .
    But the problem is that 8s Lipo is in my opinion to heavy for this cat.
    Better is to drive fast to make a light setup
    Two Lehners oder tenshocks with 4s lipo for both motors
    then i think the cat can reach over 80 mph.Maybe faster
    I try
    greetings from germany
    mudl
  16. #76
    Apr 2010
    3,480
    Hello
    I try
    mudl
    Yes, 10s, 8s, too much and too heavy.
    ________
    DAIHATSU CHARADE
  17. #77
    Apr 2010
    3,480
    OK, I've asked Jeff to make a 4mm 078 wire drive and an 8mm->.078 coupler. This should be way cool.
    What ESC should I use with the 1521 1.5d on 6s? The Turnigy 180a, Castle Hydra 120a or the Turnigy Monster 200a? I'm planning on using four 3s 30c 5000mah packs. (6s2p)
    I already have a Turnigy 180a, but have another use for it. I'd have to order the Hydra or the Monster.
    ________
    S65
  18. #78
    US
    5,557
    Any suggestions?
    It comes in a 5mm shaft which is all you need.................
  19. #79
    Apr 2010
    3,480
    Yeah, but this one came at a good price!
    https://forums.offshoreelectrics.com/...ad.php?t=14671
    ________
    Honda Cbx Series History
  20. #80
    US
    5,557
    Oh......forgot you alreagy got one.............
  21. #81
    Apr 2010
    3,480
    Yeah, but is good to know they come in 5mm shaft too! Never know, if I like it that much, I might get another one!
    EDIT: it's a 1527 1.5d, not 1521 and Castle Recommends the Hydra 180 HV or 240.
    Any advice on the ESC? I'm a little concerned about the Turnigy 180a being adequate for this... Don't want to cook the ESC.
    ________
    FERRARI DINO ENGINE
  22. #82
    US
    5,557
    Whoa! A 1527 is gonna make that baby sing!!!!!!!!!!!! Knowing that, you probably can run a bit larger than a 45.............they like prop.
    I think you will still be fine with the 180a..............unless you throw that big 52mm airplane propeller on it
  23. #83
    Apr 2010
    3,480
    Yeah, sorry for the confusion, I just had 21 on the brain.
    Cool, if the 180a will work, then I'm good to go! I just found an 8mm - 4mm coupler and am ordering the 8mm - 078 coupler & wire drive.
    This should be a ripper!
    ________
    Silver surfer reviews
  24. #84
    US
    5,557
    My friend Justin just got his in. Here is a vid of the maiden...........vid is of actual first time in the water, we filmed it today...........didnt know what to expect...................Nice boat live in person, well built and laid out.
    http://www.youtube.com/watch?v=0Z_KNRFSbr4
  25. #85
    Apr 2010
    3,480
    Ha! Those little trailers are neat. I could just see driving that to the boat dock (.5 miles away) and using the dock!
    ________
    HOME INSURANCE FORUMS
  26. #86
    6,453
    The seaking will work, depending on what prop and voltage you're going to run. What is your idea?If you run 5s and a 50mm prop or under, you may be safe. I have pushed the hell out of my seaking 180s. When I ran my 1527 1.5d it was with a CC240 lv on 5s2p. I ran up to a x455 and Things were starting to get a little warm. That motor is a freaking beast!
  27. #87
    Apr 2010
    3,480
    Hmm. The plan was to use 4 x 3s1p 30c 5kmah packs in series/parallel for 6s2p 60c 10kmah.
    I'm planning to start with a small prop, probably a 40/2 and work my way up from there. I have a feeling that the 1527 will make this guy a little top heavy, so will see how it handles. By breaking up the 6s packs, I'm hoping to even out the weight distribution and help lower the COG by installing them in the sponson bellies.
    I haven't seen the motor/sizing physically (38.8 x 101.6mm) to know what motor mount I'll end up using, but will try to get the motor as low and straight as possible. I have a 40mm mount that should work, but will see soon. This is already a long skinny hull, so who knows what the result will be. One thing's for sure, it's going to be FAST.
    ________
    Toyota Australia History
  28. #88
    Apr 2010
    3,480
    Ah, take no chances... Just ordered a Hydra 240 to run this bad boy.
    OK, my wallet hurts. Think I have all the parts I need on the way... Time to take a break.
    ________
    FORD GT40 PICTURE
  29. #89
    Jan 2010
    2,498
    Man you got alot of builds going right now,,,
  30. #90
    Apr 2010
    3,480
    Quote Originally Posted by HYDROJERRY View Post
    Yep. 5 of them. The 57" Gas Fighter Cat, the 34" Single Turnigy-Castle Apparition, the 40" Single Hydra-Castle Genesis and the 41" Twin Turnigy-Castle Sprint Cat. Oh yeah, almost forgot, and the EPOS-king of sh*ts.
    ________
    Mazda Furai Specifications
