Results 1 to 5 of 5
Thread: Twin 380 Brushless Mini-Rio !?!
    Apr 2010
    3,480
    Default Twin 380 Brushless Mini-Rio !?!
    Can it be done?
    I should have two extra 380 2850Kv motors & 60a ESC's. Should be able to squeeze a 3000mah 3s lipo in it.
    But... Will it be too heavy? Will it still float?
    Is there enough room to work in the hull?
    The question remains... Can it be done? Should it be done. The answer is... Am I going to do it. =)
    ________
    PROFESSIONAL INDEMNITY INSURANCE ADVICE
    Mar 2007
    VA
    7,212
    It shouldn't be done because there is no room.
    It shouldn't be done because it'll be too heavy.
    It shouldn't be done because there is no reason to make a mono with twins.
    It shouldn't be done because it's too much money to invest in a cheap ABS hull.
    I say go for it!
    Seriously, if you really insist on doing it, use 2 20mm motors instead of 24mm (380). You'd have better luck if you do it to a mini-v instead. (more room)
    Apr 2010
    3,480
    Well... I have the mini rio already... We'll see how ambitious I am when I have the motors in hand...
    ________
    Jailbroken
    Nov 2009
    Ca
    2,686
    Ben, are you looking for a place to put those venom motors???
    Apr 2010
    3,480
    Quote Originally Posted by forescott View Post
    Perhaps... However sadly... I don't think they are going to fit in this hull.
    I might find a nice 18-24" cat though. With less load they might last.
    ________
    E70
