....anyone done this?
It's getting hot here again and my stock UL-1 motor is running a little warmer than I like at 120+ degrees after a 1 mile run. Everything else is very cool...using the stock routing....in to ESC to Motor back to ESC then out. I need more motor cooling and already drilled out all the fittings on the stock cooling can and ESC and went to a little larger ID tubing. The only place I can still improve is the rudder. I can't change the motor in/out postion and still get my cowling on (this is not in my UL-1), so I have to improve water flow where things are.
Has anyone drilled the rudder out to get a bigger hole with better flow? Did it help? If so...how did you do it?
BTW...I just added a small 5V electric fan powered off the receiver to blow into the front of the motor...but haven't had a chance to test it yet. It doesn't push much air but may help some. Maybe at least it will help to keep the motor from cooking off in the first few minutes it's trying to cool after pulling it from the pond. That's when I tend to see/smell motors get cooked the most often.
Crash
