Page 1 of 2 12 LastLast
Results 1 to 30 of 45
Thread: New EKOS C1 Pre-Use Checklist
    Apr 2010
    3,480
    Default New EKOS C1 Pre-Use Checklist
    Learning the hard way sucks. I see I'm not the only one here who has with this tug.
    So I'll start a list of what I've learned the hard way and recommend before use:
    * Buy two (or more) 1/8th collars for the prop shaft. Install them between the shaft tube and the coupler. Make sure to use blue loctite and careful not to strip the set screws. Do not run the boat without the collar! (use the opportunity to lube the shafts) This will help prevent lost drive shafts.
    * Check Motor Mount bolts to make sure they are the correct length, if they appear long, add washers or replace if necessary. They are loose from the factory. Secure them with blue loctite and dab silicon around them to keep them from coming loose from vibration.
    * Check coupler set screws, use blue loctite, careful not to strip them out. Optionally, use a 4mm tap and re-thread the couplers to use 4mm stainless set screws.
    * Check the servo mount and apply more epoxy as required. Use blue loctite to secure screws, careful not to strip the aluminum threads.
    * Replace the bare steel set screws on the prop dogs and the rudder set screws with stainless steel. They rust almost instantly.
    * Use the cheap props util the setup has been proven, then risk the expensive ones.
    * Make sure to seal the hatch completely. There is no bailing system.
    Hope this helps!
    Note* Admin please edit, re-write or make adjustments where appropriate.
    ________
    SUZUKI KT120
    2,686
    I've got 2-more
    * As with any F.E. boat, stop and check your temps after a few minutes run-time. If any one or more components are too hot, stop immediately. Dont burn a hole in your hull!!
    * Dont make any attempts to run 4s packs with the factory electronics. No matter what the venom videos show, or what venom claims. And if your motors still work after a few minutes on 3s, consider yourself lucky!!
    Apr 2010
    WI
    77
    Default Pre use
    Remove motors before running and send back to Venom for Ammo or Feigao replacements!!!
    2,686
    Quote Originally Posted by Igoreski View Post
    Anyone looking to buy the ekos, if you can wait....,the ekos is supposed to get twin outrunners. Hopefully better quality than the current inrunners. Well see once the p-1 is released how its single inrunner holds up.
    Apr 2010
    3,480
    One word. TRAXXAS!
    I've run Revo's for years, they have their act together and will dominate if they so choose to do so.
    ________
    Marijuana bubbler
    Apr 2010
    239
    Default VENOM EKOS 4S 5000mah LIKE BUTTER
    I WISH I COULD AGREE WITH ALL THIS ................BUT
    I HAVE HAD NOTHING BUT GREAT RESULTS FROM MY EKOS AND FROM
    VENOM TECH SUPPORT
    I HAVE BEEN RUNNING 4S 5000mah
    SINCE DAY 1....8mins @ WFO NO PROBLEMS TO DATE...
    CHECK THEAD TO SEE.
    I WOULD LIKE TO ADD 1 MORE THING TO THE FE/EKOS CHECK LIST
    AFTER EACH AND EVERY RUN,NO EXCEPTIONS,EVEN IF YOU JUST COME IN TO CHECK HEAT...SPARY WD-40 OR
    SOME TYPE OF WATER SHED LUBE ON STINGER BEARINGS...DONT BE SHY WITH THE LUBE EITHER LAY IT ON.
    6,453
    How are you fitting 4s 5000's in the boat?
    Apr 2010
    239
    I'M USING DLG POWER 4S 5000mah PACKS
    THEY FIT IN WITH NO MODS AT ALL........
    Apr 2010
    3,480
    Yeah, please tell me more. My 5k's don't fit in the battery tray with the hull hatch on & I really don't want to cut up that tray to fit them. I can only get 50 x 33mm rubbing on the top hatch and use 4k's.
    PS- scubasteve you don't have to agree with anything I write. Ever.
    ________
    Rambler (Bicycle) Specifications
    Apr 2010
    3,480
    Wow, 20c/pack. That could get really HOT.
    I can't get away with 20c packs at 3s. Even 25c gets hot.
    What props are you using?
    ________
    Montana marijuana dispensary
    Apr 2010
    239
    SO FAR BEN WE HAVE BEEN ON THE SAME PAGE
    DON'T WORRY ,I'M SURE THAT WON'T LAST FOREVER.
    THE DGL POWER LIPO'S HAVE A PCB INSTALLED FROM THE FACTORY,
    NO OVER HEAT,OVER CHARGE,UNDER CHARGE,SHORT OUT, ETC....
    PACKS ARE 20C-40 BURST,GO TO DLGPOWER.COM DON'T BUY WITH OUT WHEELING AND DEALING,I PAID $200.00 SHIPPED
    FOR 4 -4CELL 5000mah PACKS.
    THAT IS CORRECT 4 PACKS DELIVERED.
    Apr 2010
    239
    I'M USING THE 36mm FIBER PROPS(STOCK)
    I WILL BE USING 36mm VENOM PRO PROPS NEXT TIME OUT
    SO FAR THE BOAT IS STOCK WITH ALITTLE EXTRA COOLING
    Apr 2010
    239
    Scrach that web site,just go to ebay type in the search member space
    (dlgpower) and go to there store they have as many as you need....
    Apr 2010
    3,480
    So a PCB prevents the battery pack from getting hot from current draw?
    Please, tell me more.
    ________
    MAGIC FLIGHT LAUNCH BOX
    Apr 2010
    239
    YES......................
    Apr 2010
    239
    the pcb stops all failures...at least thats what they tell me and so far it works perfect.
    Apr 2010
    239
    the packs get to about 120 degrees and start to shut down, the good news is thats about all the pack has left in it, cells are @ about 3.40v across the board.
    6,453
    That is impossible.If my motor is pulling 120 amps continuous and the packs are 20c 5000 mah, they are only capable of 100 amps of continuous power, They WILL get hot, voltage will drop below lvc settings of the esc and that equals problems. How can a pcb on a battery stop my motor from pulling amps? How can it STOP heat?
    6,453
    The system shuts down because the lvc in the esc is kicking in. How can a pack "start" to shut down?
    Oct 2008
    9,488
    Apr 2010
    239
    a pcb can do what ever it is designed to do.
    if you are pulling 120 amps you should not be using a 20c 5000 pack to start with.
    once battery gets to any of the cut off points it shuts down...its that simple.
    just like a pcb in a lvc stops voltage from geting to low.
    Oct 2008
    9,488
    I've got 2-more
    and sell it quick!
    Apr 2010
    239
    I don't know why you guys have so much anger built up,can't someone that has nothing but good with this boat share it with others?
    Apr 2010
    239
    GO TO THE VENOM 4S 5000mah LIKE BUTTER THEAD AND SEE HOW THIS 1 BOAT ACTS.
    6,453
    It's not anger, just questions. Seems you are the only one having any luck with this boat at all. Therefore we want to know your setup details and why it may be working.
    Apr 2010
    239
    No problem............ask away..............
    Oct 2008
    9,488
    Quote Originally Posted by scubasteve95 View Post
    not good with the pickup on the bottom of the sponson like you have
    Oct 2008
    9,488
    VENOM TECH SUPPORT
    CHECK THEAD TO SEE.
    so you only have 8mins of run time?
    and you should use grease on the bearings, WD does not lube like grease will
    Apr 2010
    3,480
    Isn't WD used to clean off good grease? At least that's what I use it for.
    ________
    Buy Vapir Vaporizer
    Apr 2010
    3,480
    BTW- I'm really glad to hear of your successes and am really looking forward to some video.
    ________
    Chrysler sunbeam specifications
