Results 1 to 17 of 17
Thread: Motor for a 12"-14" Cat (single)
    Oct 2007
    NZ
    1,521
    Default Motor for a 12"-14" Cat (single)
    As you can see I am surfing for input for motors for 2 cats as I plan on building both at the same time.
    This is for the smaller cat and I have ruled out an outrunner as a single and am now looking at these inrunners.
    Which is the better choice and why.
    http://www.hobbycity.com/hobbycity/s...idproduct=4200
    http://www.hobbycity.com/hobbycity/s...ess_Motor_(FIN)
    Both can provide me with the power (W) that I need, the esc and packs is the easy bit, I will provide the motor with plenty of energy.
    I am looking to run M4 graupner K series small props on 3S.
    May 2009
    RO
    745
    The 2835 will give you way more torque than the small 2040... plus the small one is KD, so maybe not so good quality as the Turnigy.
    Aug 2008
    7,080
    I need to learn lots more about small motors, I'm watching!!
    "Look good doin' it"
    See the fleet
    Sep 2008
    OZ
    2,865
    hey simon how about a little out runner
    Aug 2008
    7,080
    dunno, but you might need at least two of em ...
    See the fleet
    Aug 2009
    tx
    3,534
    i run a 28-47 2700kv in a 16" vee on 3s and 4s with great results a little pricey but bought before i knew about hobbycity
    link
    http://www.e-fliterc.com/Products/De...rodID=EFLM2005
    Oct 2007
    NZ
    1,521
    Interesting replies so far. Notes taken.
    Here is another option, the reviews below it indicate that a 300mm or less prop will be fine.
    http://www.hobbycity.com/hobbycity/s...r_(WaterCooled)
    I realise that it is 20mm dia and may lack a bit of torque.
    2,731
    I would go for the third one, I know somweone who ran the second one in a cat of about that size but there not the most efficient and it got hotter than I like to see even on short runs, it definatley needed water cooling, the first motor is just too big/heavy for a hull that size, more suited to your 18incher, over here we use speed400 size motors like that in our mini classes which are max 450mm (18") hull length and its the 5minute runtime we need, not the motor size that keeps the boats sensable, propped up for a few striaght line runs as I believe you run and there is plenty of power there to make a mockery of an 18" hull in all but the most glassy of conditions.
    PS, Definately keep the prop under 300mm, I have a rule of thumb that says "when the prop diameter approaches the hull length, the chances of an adverse torque reaction increase considerably"
    Aug 2009
    tx
    3,534
    16" vee 3s 28-47 2700kv 40 amp esc, not to shabby
    Sep 2009
    HI
    1,679
    What about these
    http://www3.towerhobbies.com/cgi-bin...?&I=LXLWW5&P=7
    http://www3.towerhobbies.com/cgi-bin...?&I=LXLWW4&P=7
    You can get water Jackets here
    http://cgi.ebay.com/aluminum-water-c...item439aa338fc
    A 380 can IMO is too big and should be in hulls 16" or bigger.
    Oct 2007
    NZ
    1,521
    I am now leaning towards it myself
    Cornel mentioned that it is a dubious motor
    the first motor is just too big/heavy for a hull that size, more suited to your 18incher, Could do
    Propped up or celled up ? do I go 2S and go up a prop or go 3s and down on the prop.
    Love a typo !! you know I meant 30mm
    Quote Originally Posted by BakedMopar View Post
    What about these
    Nice links an I'll keep them but for now the big issue is shipping, by the time i land them the post is more than the item.
    George, do you think the 20mm motor may be the go too?
    Sep 2008
    OZ
    2,865
    i still think the scorpion 22mm are better motors, yes they are more $$$ but rebuild able
    and can take some very high temps. and this is a Aus $$$ not u.s
    http://www.arkinnovations.com/shop/i...ex&cPath=16_46
    Oct 2007
    NZ
    1,521
    Quote Originally Posted by ozzie-crawl View Post
    Nice motors there Scott, but this will deffo be a Inrunner job. It will be small and narrow so an OR will flip it too easily.
    I may yet go OR in the bigger 18"(wet)20"Loa cat.
    Looking and looking for now.
    Sep 2008
    OZ
    2,865
    hopfully there in runners will be out very soon
    up to 40mm are 4 pole over 40 mm are 8 pole .had a email from them about 6 weeks ago and they said 2-3 months
    6,453
    The ammo motors are excellnt! http://cgi.ebay.com/Great-Planes-Amm...item562e963947 Check out the other sizes and winds they have as well.
    Sep 2009
    HI
    1,679
    IMO the 380 cans are too heavy (especialy the L versions which are 58mm long) and eat too much amps. While I can only speak for a 17.5" hydro thats my take. A buddy runs a couple of Minicat stuff with 20mm motors and they are fast and have decent run time. He gets around 4-5 minutes wide open in his hydro with a 2200 pack. I get 1-2 minutes out of a 2200 pack with a Feigao 8l.
    If you really want a 380 size (28mm) go with a short can 45mm and under. With a 380 you can spin a bigger prop. But you need higher amp escs.
    Oct 2007
    NZ
    1,521
    I have done a bit more thinking on this one and have come up with an interesting idea.
    My ~34"cat has about 1600W of calculated power and run well.
    My ~25" cat ( now dead) had about 1000W of calculated power and was very fast.
    I see a pattern here
    About 70% hull size reduction runs on about 70% of the power, so far so good.
    One new hull i plan on build will be 18"(wet) 20"loa and most of my reading points to about 750W power setups. This is where the light bulb came on.
    The smallest cat on the paper at the moment will have aboat 13"wet and 14"+ loa. This should then get by with about 250W of power.
    I did a few paper cutouts and have shown my "formula" to be based on plan view sizes. Given that my cats are close to the same design and proportional build construction I now see this as a power to size ratio.
    Now all I need to do is suit up about 250W of power to feed to a 27mm Graupner prop.
    I plan to use the Graupner 2318 series M4 threaded props until I find the right size and then if needed go to a metal one.
    Possible power combo#1
    20x40mm (130L) 4850kv Inrunner max load 25A?? (185W) Add more for short sprints with cooling !!
    40A esc
    1600 30-40C (48-64A) 2S1P pack
    Possible power combo#2
    24x35mm (370s) 4400kv Inrunner Max load 26A (192W)
    Same pack, and esc.
    Last resort is to go with a 380S.
    I am leaning toward the smaller motors as that seems to be a fairly successful size to transplant into the Pro-Boat Mini-C and I have seen a few clips of them going nuts on small setups.
    This is deffo a fun boat, not a saw or racer.
    I am enjoying the research and thought that all of this takes.
