Results 1 to 13 of 13
Thread: How many days do you keep your lipos at full charge?
    Apr 2010
    MO
    50
    Question How many days do you keep your lipos at full charge?
    So I'm still learning about these lipo batteries... I know I've read in the off season to keep them at about 3.9-3.8 volts. But what about during the season?
    If you plan on running your boat every week or once every two weeks, do you keep your lipos at full charge, or only charge them a day before?
    - I'm new, and promise to pay forward all help received
    May 2009
    535
    Charge them to 50% for storage and charge them to 95% the night before you use them...they will last longer.
    WA
    2,038
    Quote Originally Posted by MLJones8 View Post
    I keep all my packs at a pretty much full charge during the 7 to 8 months out of the year (no real harsh winters here to keep me off the lakes) But I do take them down to 3.5 volts for the remainder of the year where they sit on the shelf. Discharged cells, down to a certain voltage,do not degrade cell capacity. Its taking them below that level and leaving them there that promotes chemical degradation. Then you cannot recover from the electrolyte depletion. Remember you are essentialy suspending neg ions in chemical bonds.
    John
    Change is the one Constant
    Apr 2010
    MO
    50
    Quote Originally Posted by bigwaveohs View Post
    This seems to be the common reply, meaning if my lipos are 2S 7.4 volts, then to store each cell at (7.4/2)=3.7 volts. I guess my question could have been worded more directly. What defines storage? A day? A week?
    Quote Originally Posted by m4a1usr View Post
    John
    Great thanks for the input... so John, I'd say you define storage as over a month?
    WA
    2,038
    As far as defined you could infere storage as windows of time as great as months, plural. I routinely leave packs unattended for 60, 90 days at 3.5 volts per cell. Been running those same packs for an excess of 3 years and no performance degradation. The important rule to remember is to not leave them fully charged, 4.24 vdc for extended periods. (Longer then 6 months). The industry recommends lithium polymer batts to be stored at 40 to 60% of capacity for extended periods (6 months and longer). My own opinion is that a lipo stored at a 50% charge for 2 years is going to be fine. But I have not done nor seen a study to put that in to fact.
    I mistakenly stated neg ion suspension. That is incorrect. They are actually positive in their charge suspension. As current flows from positive to negative in a DC circuit. My bad!
    John
    Oct 2007
    NZ
    1,521
    This is a good one to read. I learn more ech time I visit.
    I see me (waiting for the wind to go) "storing" packs for 3-5 days at 4.20v as not a big drama.
    If I am not going boating for 4-6 weeks , then I should drop them to 3.5 or close ? or should I only worry if I am going to store them for a few months.
    Boating here is close to all year round, but I am a sook and like the flat calm water.
    Sep 2008
    OZ
    2,865
    i usally charge battries the day i run,after running them i leave them till the next time i run
    batteries are usally between 3.7-4 volts after a run.
    any more than a 4-6 weeks i charge/discharge to 3.6v a cell for storage
    WA
    2,038
    Quote Originally Posted by ozzie-crawl View Post
    batteries are usally between 3.8-4 volts after a run.
    Amen Ozz. I think thats probably the best battery management technique. Unless you know your heading to the lake soon just keep them where they are after a day out and providing you know what they are down to.
    John
    Sep 2008
    OZ
    2,865
    thanks john,plus its the easiest
    Fr
    1,300
    top quality chargers have a storage charge function witch charge at 60%, I bet that's the best!
    Emmanuel
    I'm french but I doubt I really am!
    http://pagesperso-orange.fr/pleindetrucs/
    Sep 2008
    OZ
    2,865
    so do my cheapies from hobby king
    they drop the pack to 3.6v a cell i think, i figure after a run my cells are between
    3.7-4 volts so should not hurt any thing for a few weeks
    Fr
    1,300
    you're right ozzie, if the voltage is around 3.7V that must be perfect, but what if the voltage doesn't drop? I'm refering to the Rhino's where the voltage remains high even when the batt is empty!!!
    Emmanuel
    Sep 2008
    OZ
    2,865
    yes the turnigy packs do the same, makes lvc usless
    but after a run if you check your packs the voltage will still be down
    the packs just dont drop of under load as much as the low C rated batts that we used to run.
    i very rarly balance my batts and dont use lvc, i time my runs, just use the count down timer on my tx and i then know how much mah i have used
