Results 1 to 14 of 14
Thread: Carbon Fiber, please tell me your tips and tricks!
    Aug 2007
    952
    Default Carbon Fiber, please tell me your tips and tricks!
    I have laid down some fiber cloth, and while it looked ok, I wasn't happy with the results. I have seen some on this site that looks great! I have had much better luck with laying fiberglass cloth.
    Is it better to use hairspray to keep the fiber from getting disturbed rather then adhesibe spray while you cut to size?
    Do you use a really soft brush to apply epoxy on the fibers? I used just a acid brush and noticed it worked good, but disturbed the super tiny fibers.
    I saw Randy's wright up but it was missing some pics, he used CA to glue instead of epoxy.
    It would be nice if someone could do a writeup of a few different methods and sticky them. I'm applying it to wood built boat, but would like to know the different methods of appying to different material hulls. Thanks guys.
    Twin power =
    Jan 2010
    fl
    567
    Quote Originally Posted by ace028 View Post
    Hi ACE
    There is a thread on here somewere that had a really good wright about about laying CF cloth . I think it was RANDY @ BBY racing that wrote it up . Hopefully some here can link you to the thread as i dont remeber the title of the thread.
    Jan 2008
    AU
    549
    Talking
    Ace,
    Theres some good reading in this thread on carbon fiber glassing.
    Check it out mate.
    https://forums.offshoreelectrics.com/...ad.php?t=13126
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    Oct 2008
    wa
    389
    Here are a couple tricks. Take a paint brush, cheapo one work fine, and cut off 1/2 of the length, makes a nice applicator for getting epoxy into the cf fibers.
    Application teqnique.
    This requires some timing, just be aware. Get along cure epoxy for the cf (or regular resin, doesnt matter) and have your work surface and a seperate glass work surface large enough for the pieces your working with (giant silicone cooking mats work great. you will have to secure them though)
    Mix resin or epoxy according to weight directions and "paint" surface number one neatly, but quickly. Take the mat and on the separate surface prep it, ensuring you saturate it with just enough resin or epoxy to get all fibers wet, the mat should look semi dry not pooled with resin or epoxy, if it does you have to much on it.
    wait for the tack stage on both pieces, you will have a short overlap of time to work with this roughly 10 minutes. The next part is a bit messy but results are great. Apply your mat to your work and press together, similar to contact cement the two surfaces will adhere together and you can work the mat into curves, crevaces and it will stay, touch up any seam areas and apply your plastic film to ensure a smooth surface and let cure. Build up as needed and sand to your taste, polish.
    Not nearly as hard as it sounds and quick once you get the hang of it, the only draw back is the work area for the mat piece. took me a few practice runs but this system works great if you dont like the hassle of vacuum bagging.
    Jul 2007
    Or
    626
    Grail,
    When you say:
    Quote Originally Posted by graill View Post
    What kind of plastic film are you using and where do you get it from? It sounds like a great idea, since you are also insulating the CF from the electronics. Less chance for accidental shorts.
    Thanks,
    Brad
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
    Oct 2008
    wa
    389
    Quote Originally Posted by FE Wannabe View Post
    Grail,
    When you say:
    Thanks,
    Brad
    Bagging material. But use to make the surface smooth instead of using it to vacuum bag. It comes in any size you need and from nearly all the composite companies or any fiberglass/CF that sell the building supplies, cheap stuff.
    Jul 2007
    Or
    626
    Grail,
    Thanks for the response,
    By the way you do great work!
    Sep 2007
    Co
    3,915
    I use low temp Peal Ply or for bagging perforated Peal Ply. Aero Space Composite make or sells some good stuff that makes it real shiny. I also have a layer of FG inside the CF to keep it safe from shorts.
    Randy
    BBY Racing
    Jul 2007
    Or
    626
    Thanks for the info Randy.
    Brad
    Aug 2009
    IN
    980
    Peal Ply
    Peal ply works great. Will take some excess resin with it and it leaves the inside of the hull non-gloss so it is ready to have anything else glued to it. Gloss is not good for adhesion.
    Grail, I think I got confused. You are only laying the carbon fiber in right? when you say "Mat" you are talking about a plastic piece that holds the wetted CF until it tacks, then you use it as a carrier to move the wetted CF into the hull. Am I on the right track?
    Carbon FiberYou can also get normal glass that is colored to look like carbon fiber. You do not need it in a FE boat. I am constantly told you need the weight to hold them down, yet people keep putting CF in the boats???? Why not just use 2 or 3 layers of glass?
    Brian
    Oct 2008
    wa
    389
    Quote Originally Posted by befu View Post
    Peal Ply
    Brian
    When i refer to the mat i refer to the CF or "work". When the proper amount of resin (whatever type is applied) the mat or work can be moved around easily, wear gloves. And by moved around i mean from the prep area to whatever your applying it to.
    Jul 2010
    MA
    40
    ive been doing HPR rocketry for years. i like sollercomposites.com. and i'd definitely go with a hybrid kevlar/glass cloth. CF sheilds radio signals...i know it's not an issue on the bottom of the hull, but then you gotta consider cost, and that CF is incredibly hard to work with. (it frays on the ends like nothing else...)
    i also agree that CF is way overkill for an RC boat. the only way i could see it being necessary is if you had a deep vee or huge cat that was traveling 200+ mph. it's extremely rigid, on the flip side, it's quite brittle and will break with a good enough shock. (i've seen it happen in rockets with too much stress on 1 point).
    just my .02 cents. as i say i've been working with the stuff for years, i wouldn't wish CF slivers or frayed edges on anyone. the kevlar/FG mat is a lot easier to work with, and provides ample strength. (and looks AWESOME!)
    Dec 2008
    Ov
    918
    Ample ?
    Even more !
    Carbon for strenght in the lenght of the fibres.
    Kevlar for strenght on a 90 degr. angle on the fibres.
    May 2007
    no
    415
    good thread here.... thanks
